    Help needed simple API based module
    19 Posts 4 Posters 12.1k Views 4 Watching
    • W Offline
      washichi
      thank you! It’s now working :)
      I thought that my scheduleupdate was working but it didn’t (only 2 times )
      with the Log function I could find the problem easy .
      • yawnsY Offline
        yawns Moderator
        great. Now tidy up your code ;) and present your module in modules showcase
        ooom416354O 1 Reply Last reply Reply Quote 2
        • ooom416354O Offline
          ooom416354 @yawns
          @washichi @yawns this is great work. I am wondering, would this completed code be kind of a base for making other API calls which return data in JSON format?
          W cowboysdudeC 2 Replies Last reply Reply Quote 1
          • W Offline
            washichi @ooom416354
            @ooom416354 Yes, but other modules are also that.
            I used the default module “weatherforecast” it is an simple api based module that gets the data and displays it in a table.
            I’m now trying to add a map, and then display the ISS current position on that, but implementing this in a module is a lot harder then normal javascript :p.
            ooom416354O 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator
              @ooom416354
              Yes, kind of. At least with JSON calls without additional headers. The you need to use request and a node_helper
                ooom416354 @washichi
                @washichi Yea, I am still not even sure how to translate the returned JSON to an actual visual table on the mirror. Not very good at this lol
                cowboysdudeC 1 Reply Last reply Reply Quote 1
                • cowboysdudeC Offline
                  cowboysdude Module Developer @ooom416354
                  @ooom416354 It could be yes ;)
                    @ooom416354 said in Help needed simple API based module:
                    Me either but won’t stop me from trying :)
                      ooom416354 @cowboysdude
                      @cowboysdude yup I agree with that!
