    Help needed simple API based module
    19 Posts 4 Posters 13.3k Views 4 Watching
    • W Offline
      washichi @yawns
      @yawns yeah that solved it, my module is now at least showing :).
      sorry, stupid mistake haha, I though I checked it .
      Thanks for your help
      • Y Offline
        yawns Moderator
        okay, next thing is your updateISS function. I modified it for you to get you started:
        	updateISS: function() {
        		var self = this;
        		var url = self.config.apiBase;
        		var opennotifyRequest = new XMLHttpRequest();
        		opennotifyRequest.open("GET", url, true);
        		opennotifyRequest.onreadystatechange = function() {
        		if (this.readyState === 4) {
        			if (this.status === 200) {
        				var resp = JSON.parse(this.response);
        				this.latitude = resp.iss_position.latitude;
        				this.longitude = resp.iss_position.longitude;
        				this.timestamp = resp.timestamp;
        				this.message = resp.message;
        			self.updateDom();
        	opennotifyRequest.send();
        • W Offline
          washichi @yawns
          @yawns thank you!
          the module shows now this.message and refreshes it with the schedule.
          however I am still doing something wrong in my request:
          		var url = this.config.apiBase;
          		var self = this;
          		this.message = "in updateISS";
          		self.message = "request status: "+ to.String(this.status); // not displayed
          				self.latitude = resp.iss_position.latitude;
          				self.longitude = resp.iss_position.longitude;
          				self.timestamp = resp.timestamp;
          				self.message = resp.message;
          				self.message = "dit gebeurt niet";
          	self.updateDom();
          I can’t set message in that function, for example line 86. I use self/this wrong, or the function isn’t executing. but the code continous because when I set the message before or after that function it gets displayed.
          • Y Offline
            yawns Moderator @washichi
            @washichi
            hm. Did you try to output latitude and longitude as well in getDom to see if this is working?
            • W Offline
              washichi @yawns
              @yawns No I didn’t, but that should be exactly the same thing.
              If I hardcode the (any) variable in “issRequest.onreadystatechange = function() {”
              then it just doesn’t display, so it looks like it isn’t going in that function.
              but if I hardcode the (any) variable after that function It displays.
              So I can display the variable (message), but the variable doesn’t get filled with the request.
              • Y Offline
                yawns Moderator
                Simple way to test if it entering the function:
                Log.error("function entered");
                Press F12 in browser, check for console output and refresh the website. If the function is entered you will see “function entered” in the console.
                • W Offline
                  washichi
                  thank you! It’s now working :)
                  I thought that my scheduleupdate was working but it didn’t (only 2 times )
                  with the Log function I could find the problem easy .
                  • Y Offline
                    yawns Moderator
                    great. Now tidy up your code ;) and present your module in modules showcase
                    O 1 Reply Last reply Reply Quote 2
                    • O Offline
                      ooom416354 @yawns
                      @washichi @yawns this is great work. I am wondering, would this completed code be kind of a base for making other API calls which return data in JSON format?
                      W cowboysdudeC 2 Replies Last reply Reply Quote 1
                      • W Offline
                        washichi @ooom416354
                        @ooom416354 Yes, but other modules are also that.
                        I used the default module “weatherforecast” it is an simple api based module that gets the data and displays it in a table.
                        I’m now trying to add a map, and then display the ISS current position on that, but implementing this in a module is a lot harder then normal javascript :p.
                        • Y Offline
                          yawns Moderator
                          @ooom416354
                          Yes, kind of. At least with JSON calls without additional headers. The you need to use request and a node_helper
                          • O Offline
                            ooom416354 @washichi
                            @washichi Yea, I am still not even sure how to translate the returned JSON to an actual visual table on the mirror. Not very good at this lol
                            • cowboysdudeC Offline
                              cowboysdude Module Developer @ooom416354
                              @ooom416354 It could be yes ;)
                                @ooom416354 said in Help needed simple API based module:
                                Me either but won’t stop me from trying :)
                                • O Offline
                                  ooom416354 @cowboysdude
                                  @cowboysdude yup I agree with that!
