    Help needed simple API based module
    19 Posts 4 Posters 13.2k Views 4 Watching
    • W Offline
      washichi
      I just started creating modules, and don’t have any javascript experience.
      I am trying my luck on a really simple API based ISS tracker module.
      but I am doing something wrong.
      here is my code: https://github.com/washichi/MMM-ISS-current-location
      the logs mm-out-0.log &mm-error-0.log don’t give me weird errors.
      and I compiled it with http://liveweave.com/ (can’t find the right plugin for sublime3 ) so I’m doing something wrong in the code.
      I hope someone can help me to see what I did wrong.
      • cowboysdudeC Offline
        I’m no programmer [yet] LOL But I will tell you that you also need something like this in there:
        notificationReceived(notification, payload, sender)
        That MagicMirror core has the ability to send notifications to modules. Or even better: the modules have the possibility to send notifications to other modules. When this module is called, it has 3 arguments:
        notification - String - The notification identifier.
        payload - AnyType - The payload of a notification.
        sender - Module - The sender of the notification. If this argument is undefined, the sender of the notififiction is the core system.
        Example:
        if (sender) {
        Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
        } else {
        Log.log(this.name + " received a system notification: " + notification);
        Note: the system sends two notifications when starting up. These notifications could come in handy!
        ALL_MODULES_STARTED - All modules are started. You can now send notifications to other modules.
        DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
        socketNotificationReceived: function(notification, payload)
        When using a node_helper, the node helper can send your module notifications. When this module is called, it has 2 arguments:
        Note 1: When a node helper sends a notification, all modules of that module type receive the same notifications.
        Note 2: The socket connection is established as soon as the module sends its first message using sendSocketNotification.
        Example:
        Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
        • W Offline
          washichi @cowboysdude
          @cowboysdude
          mhh okay, thank you! I’ll try to implement it, looking to the default weatherforecast module as example.
          from the modules readme I don’t totally understand why I need this, it sounds like optional . and I don’t have notifications. (or are updating modules seen as notification?)
          • Y Offline
            yawns Moderator
            Hi, first spotted error:
            Module.register("ISS-current-location",{
            This should be
            Module.register("MMM-ISS-current-location",{
            Otherwise your module won’t be called.
            W 1 Reply Last reply Reply Quote 1
            • W Offline
              washichi @yawns
              @yawns yeah that solved it, my module is now at least showing :).
              sorry, stupid mistake haha, I though I checked it .
              Thanks for your help
              • Y Offline
                yawns Moderator
                okay, next thing is your updateISS function. I modified it for you to get you started:
                	updateISS: function() {
                		var self = this;
                		var url = self.config.apiBase;
                		var opennotifyRequest = new XMLHttpRequest();
                		opennotifyRequest.open("GET", url, true);
                		opennotifyRequest.onreadystatechange = function() {
                		if (this.readyState === 4) {
                			if (this.status === 200) {
                				var resp = JSON.parse(this.response);
                				this.latitude = resp.iss_position.latitude;
                				this.longitude = resp.iss_position.longitude;
                				this.timestamp = resp.timestamp;
                				this.message = resp.message;
                			self.updateDom();
                	opennotifyRequest.send();
                • W Offline
                  washichi @yawns
                  @yawns thank you!
                  the module shows now this.message and refreshes it with the schedule.
                  however I am still doing something wrong in my request:
                  		var url = this.config.apiBase;
                  		var self = this;
                  		this.message = "in updateISS";
                  		self.message = "request status: "+ to.String(this.status); // not displayed
                  				self.latitude = resp.iss_position.latitude;
                  				self.longitude = resp.iss_position.longitude;
                  				self.timestamp = resp.timestamp;
                  				self.message = resp.message;
                  				self.message = "dit gebeurt niet";
                  	self.updateDom();
                  I can’t set message in that function, for example line 86. I use self/this wrong, or the function isn’t executing. but the code continous because when I set the message before or after that function it gets displayed.
                  • Y Offline
                    yawns Moderator @washichi
                    @washichi
                    hm. Did you try to output latitude and longitude as well in getDom to see if this is working?
                    • W Offline
                      washichi @yawns
                      @yawns No I didn’t, but that should be exactly the same thing.
                      If I hardcode the (any) variable in “issRequest.onreadystatechange = function() {”
                      then it just doesn’t display, so it looks like it isn’t going in that function.
                      but if I hardcode the (any) variable after that function It displays.
                      So I can display the variable (message), but the variable doesn’t get filled with the request.
                      • Y Offline
                        yawns Moderator
                        Simple way to test if it entering the function:
                        Log.error("function entered");
                        Press F12 in browser, check for console output and refresh the website. If the function is entered you will see “function entered” in the console.
                        • W Offline
                          washichi
                          thank you! It’s now working :)
                          I thought that my scheduleupdate was working but it didn’t (only 2 times )
                          with the Log function I could find the problem easy .
                          • Y Offline
                            yawns Moderator
                            great. Now tidy up your code ;) and present your module in modules showcase
                            O 1 Reply Last reply Reply Quote 2
                            • O Offline
                              ooom416354 @yawns
                              @washichi @yawns this is great work. I am wondering, would this completed code be kind of a base for making other API calls which return data in JSON format?
                              W cowboysdudeC 2 Replies Last reply Reply Quote 1
                              • W Offline
                                washichi @ooom416354
                                @ooom416354 Yes, but other modules are also that.
                                I used the default module “weatherforecast” it is an simple api based module that gets the data and displays it in a table.
                                I’m now trying to add a map, and then display the ISS current position on that, but implementing this in a module is a lot harder then normal javascript :p.
                                • Y Offline
                                  yawns Moderator
                                  @ooom416354
                                  Yes, kind of. At least with JSON calls without additional headers. The you need to use request and a node_helper
                                  • O Offline
                                    ooom416354 @washichi
                                    @washichi Yea, I am still not even sure how to translate the returned JSON to an actual visual table on the mirror. Not very good at this lol
                                      cowboysdude Module Developer @ooom416354
                                      @ooom416354 It could be yes ;)
                                        @ooom416354 said in Help needed simple API based module:
                                        Me either but won’t stop me from trying :)
                                        • O Offline
                                          ooom416354 @cowboysdude
                                          @cowboysdude yup I agree with that!
