    MMM-MotionDetector - Error: getUserMedia
    4 Posts 1 Posters 963 Views 1 Watching
      debaetstony
      I reinstalled raspbian with the MMM-MotionDetector module and now keep getting following message:
      Error: getUserMedia is not implemented in this browser
      Tested older and new versions of raspbian on Pi4, also Stretch version on Pi3.
      Config > address: “0.0.0.0”,
      When changing to “localhost” or “127.0.0.1” you get the “NotFoundError: Requested device not found”
      Anyone ideas?
      I also noticed that in the new Buster the raspi-config camera has changed from camera to legacy camera. Could this have something to do with it?
        debaetstony
        Found a workaround;
        Run as server and start chromium > authorize the camera.
        Of cours not the same.
          debaetstony
          The above workaround doesn’t always work either!
          Answer from Github which does work;
          FYI: I switched back to the legacy raspios (https://www.raspberrypi.com/news/new-old-functionality-with-raspberry-pi-os-legacy/) and there the bug doesnt seem to appear.
            debaetstony
            It looks like this won’t work again with the latest version of MagicMirror.
            When I look at Chromium, you can activate the camera on localhost & 127.0.0.1 (permission for this site) but on 0.0.0.0 it is grayed out. Think this will also be the case for Electronjs.
            Only possibility I see is;
            • list itemmake Electronjs authenticate the camera when starting module
            • list itemmake Electronjs authenticate the camera when starting MagicMirror
              set camera permission for 0.0.0.0
