    Default Calendar
    17 Posts 3 Posters 7.6k Views 3 Watching
    • plainbrokeP Offline
      plainbroke
      Re: Default Modules
      Is there a way to have 2 calendars I used to have 1 for Birthdays and one for holidays. I simply renamed the default calendar to calendarh and moved it to the moduels folder and in the config.js the config was under calendarh
      I also renamed the css and js files for calendarh directory. I had to go in and change a few things in the js and the css. It all worked so nice. now I can not do that for some reason. Any suggestions what I may be doing wrong this time… ?
              position: "middle_center",
              header: "Birthdays",
                      fade: false,
                      maximumEntries: 4,
                      timeFormat: "absolute",
                      urgency: 3,
                      getRelative: 24,
                              symbol: "birthday-cake",
                              url: "https://calendar.google.com
              module: "calendarh",
              header: "US Holidays",
                      fade: false,
                      maximumEntries: 4,
                      urgency: 3,
                      getRelative: 24,
                              symbol: "h-square",        url:"https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics"
      • swvalentiS Offline
        swvalenti Project Sponsor @sdetweil
        @sdetweil that worked error was syntax, got it working thanks sam
          sdetweil @plainbroke
          @plainbroke you didn’t need to do all that.
          just define another calendar module if you want them separate.
          or add another entry in the calendars list if u want the events combined
            plainbroke
            Sorry I do not understand what you mean. “define another calendar module”.
            I have the events combined right now I really would like them as two seperate calendars. I use carousel remember. My Calendars cover most of the screen.
              @plainbroke
              module:'calendar':
              position:'top_left',
              classes:'page1'
              config:{
              and
              module:'calendar':
              position:'top_right',
              classes:'page2'
              config:{
              use mmm-pages, easier
              the modules list for pages is
                 [   'page1' ],
                 [   'page2' ]
              all the modules u want on page 1 use the page1 class
              (it’s just a name, but pages looks for classes, and carousel does not)
              plainbrokeP 1 Reply Last reply Reply Quote 0
                plainbroke @sdetweil
                Thanks I will look into it when i get time. I have carousel working pretty well now. 33 out of the 40 I had working on MM before update to 2.18, so I am plenty happy…
                swvalentiS 1 Reply Last reply Reply Quote 0
                  swvalenti Project Sponsor @plainbroke
                  I setup two different calendars in the config with url: “”, and url:“” however only one displays, am I missing something?
                    sdetweil @swvalenti
                    @swvalenti in the module config, the calendars sestting is a list
                               url:   // first calendar ics
                              symbol:
                                     url:    // second calendar ics
                                    symbol:
                       ]   // <- end of list
                      @sdetweil This is what I have but crashes the mirror…its the same as you put
                      						symbol: "calendar-check",
                      						url: ""
                      						url: ""
                        sdetweil @swvalenti
                        @swvalenti show me the output of ‘crashes the mirror’
                          @sdetweil Just goes to a black screen and throws a bunch of red errors in the cmd window, cant even run dev, one at a time works fine
                            sdetweil @swvalenti
                            @swvalenti show me the errors in the cmd window…
                              @sdetweil it wont let me i have to end task cause it wont let me exit mirror
                                sdetweil @swvalenti
                                @swvalenti ctrl-m will minimize
                                crel-c will end in the cmd window
                                  @sdetweil yea i wont minimize that why i have to end task
                                    sdetweil @swvalenti
                                    @swvalenti alt-spacebar, n
                                    never had it not work…
                                    this is why I use ssh for all my access… never have keyboard troubles…
                                        sdetweil @swvalenti
                                        @swvalenti awesome! glad you got it…
