    No communication back from node_helpers?
    3 Posts 3 Posters 957 Views 3 Watching
      MikeBishop
      I just upgraded to the latest version, and most of my modules are broken, specifically any module that uses a node_helper. It looks like messages from the modules are reaching the helper, but no responses are coming back to the client.
      I tried re-cloning the MM repo and copying over the config/modules with a fresh npm install, but it produces the same result. I feel like I’m missing something basic here, but I’m not sure what else to check.
      • mumblebajM Offline
        mumblebaj Module Developer @MikeBishop
        @mikebishop after updating you have to go into each module and run npm install for each module that has a package.json. You problem is probably related to modules that use deprecated modules like request and a few others.
        This this post for more details.
          sdetweil @mumblebaj
          @mumblebaj my upgrade script will do this as part of the upgrade process
          see
