    need help pleas MMM-MyCalendar does not work
    3 Posts 2 Posters 739 Views 2 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      it shows this error
      [ERROR] (node:32999) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 pipe listeners added to [Request]. Use emitter.setMaxListeners() to increase limit
      [06.03.2022 10:38.59.854] [ERROR] Calendar Error. Could not fetch calendar:  http://p49-calendars.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4 FetchError: maximum redirect reached at: https://p49-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4
          at ClientRequest.<anonymous> (/Users/patrickhahn/MM/node_modules/node-fetch/lib/index.js:1526:15)
          at ClientRequest.emit (node:events:394:28)
          at HTTPParser.parserOnIncomingClient (node:_http_client:621:27)
          at HTTPParser.parserOnHeadersComplete (node:_http_common:128:17)
          at TLSSocket.socketOnData (node:_http_client:487:22)
          at TLSSocket.emit (node:events:394:28)
          at addChunk (node:internal/streams/readable:315:12)
          at readableAddChunk (node:internal/streams/readable:289:9)
          at TLSSocket.Readable.push (node:internal/streams/readable:228:10)
          at TLSWrap.onStreamRead (node:internal/stream_base_commons:199:23)
        type: 'max-redirect'
      [06.03.2022 10:38.59.855] [ERROR] Calendar Error. Could not fetch calendar:  http://p49-calendars.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmoejzKgKtQEAj1Q0AC7gRo21J2MHnicr6qKtVkCDMwA10iGZhj93kDVpLZUe38RY28 FetchError: maximum redirect reached at: https://p49-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmoejzKgKtQEAj1Q0AC7gRo21J2MHnicr6qKtVkCDMwA10iGZhj93kDVpLZUe38RY28
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @Stoffbeuteluwe
        @stoffbeuteluwe
        Same problem.
        @Thorn2910
        Woha!!!
        I just unchecked the Public calendar in iCloud and rechecked it again - this changed the link to
        webcal://p102-caldav.icloud.com/published/2/xxx
        and now it works again!
        Changing to solved!
        StoffbeuteluweS 1 Reply Last reply Reply Quote 1
          Stoffbeuteluwe Project Sponsor @JerryP
          @jerryp thanks …yes that was the problem
