    MMM-Screencast Position
    8 Posts 4 Posters 2.3k Views 4 Watching
    • P Offline
      poucedeleon
      Have installed MMM-Screencast on my MagicMirror2 and it works great. I am trying to position the screen in a specific position on my monitor. My Monitor is portrait, and I want the screen at middle point hormonally on the right side. It is an area where I don’t have anything on the screen. I have added x: and y: to my config.js, but no matter what numbers I type the screen does not move. Has anyone been able to move the screen, and maybe tell me what I am doing wrong.
      module: "MMM-Screencast",
      position: "top_right", // This position is for hidden <div /> ect.
      config:   {
                     height:   300,
                     width:   500,
                     x:   -700,
                     y:   0,
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @poucedeleon
        @poucedeleon
        Possible values are top_bar , top_left , top_center , top_right , upper_third , middle_center , lower_third , bottom_left , bottom_center , bottom_right , bottom_bar , fullscreen_above , and fullscreen_below
                config:  {
                       position:   " ", //Possible values are top_bar , top_left , top_center , top_right , upper_third , middle_center , lower_third , bottom_left , bottom_center , bottom_right , bottom_bar , fullscreen_above , and fullscreen_below
                       height:   300,
                       width:   500,
                       x:   -700,
                       y:   0,
        • P Offline
          poucedeleon
          This is from the config option section
          Configuration options for MMM-Screencast
          Option Description
          position Required The position of the screencast window.
          Options: [‘bottomRight’, ‘bottomCenter’, ‘bottomLeft’, ‘center’, ‘topRight’, ‘topCenter’, ‘topLeft’]
          Type: string
          Note: This module config actual sets the location, not the magic mirror position config. NOTE
          x Optional (required if y is used) Window’s left offset from screen. Takes precedence over position.
          Type: number (pixels)
          y Optional (required if x is used) Window’s left offset from screen. Takes precedence over position.
          Type: number (pixels)italicised text
          • P Offline
            poucedeleon @poucedeleon
            @poucedeleon Maybe I should take “position:” out if I am using x & y?
              sdetweil @poucedeleon
              @poucedeleon note that there are TWO position settings
              from the readme
                             module: "MMM-ScreenCast",
              		position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
              			position: 'bottomRight',
              the 1st one is thee MM position, there MUST be something, else NO content will be displayed
              as MM doesn’t know where to put it.,.
              the second (different spelling) is the modules private info… don’t know how it uses that
                ramisthand76
                this is really helpful post for me, thank you for your comments
                • P Offline
                  poucedeleon @sdetweil
                  @sdetweil I know spelling is critical. On your example position: :“bottomRight” is this spelling correct?
                    @poucedeleon
                    that is a MMM-ScreenCast property… not MagicMirror
                    but, yes whatever way the module expects, exact syntax is important, including upper/lower case.
