    MMM-network-signal Module
    6 Posts 2 Posters 1.5k Views 1 Watching
      BrotherDan
      I am having difficulties adding the MMM-network-signal module. When I add it to my config.js, I can no longer boot into MagicMirror. I have cloned it successfully to my modules directory. When I modify my config.js to add this, I boot into a blank screen. I can recover by renaming my saved config file and boot up successfully. Any ideas as to why adding this module causes this behavior?
        BrotherDan @BrotherDan
        @BrotherDan
        …Issue resolved…
        Operator error. I needed to make certain I installed the needed dependencies in the MMM-network-signal folder…
        • swvalentiS Offline
          swvalenti Project Sponsor
          @BrotherDan give this a try
          swvalentiS B 2 Replies Last reply Reply Quote 0
            swvalenti Project Sponsor @swvalenti
            I got it working on my mirror just fine
              BrotherDan @swvalenti
              @swvalenti
              Thanks for your advice. The package.json is present.
              BrotherDan
                @BrotherDan
                An update…
                This may be symptomatic of a larger issue. I see the same action when I try to add a different module…Ideas?
                  @BrotherDan
                  …Issue resolved…
