    CPU-Temperature as a graph with RRDtool
    1 Posts 1 Posters 1.3k Views 2 Watching
    • thgmirrorT
      thgmirror
      I added a graph about the progress of the CPU-temperture of my RPI3 to my MM via RRDtool:
      It looks a little bit nerdy, but the temperature is a nerdy hardware characteristic. OK, it is not so beautiful like grafana…but much easier to use.
      Therefor, it needs only a few steps to realize it:
      sudo apt-get install rrdtool
      will install it.
      Only one time create the database in the terminal session:
      rrdtool create cputemp.rrd --step 300 DS:temp:GAUGE:600:-20:90 RRA:AVERAGE:0.5:12:24 RRA:AVERAGE:0.5:288:31
      Add two tasks to crontab:
      2-57/5 * * * * rrdtool update cputemp.rrd N:$(vcgencmd measure_temp | cut -c "6-9")
      moves every 5 minutes the temperature to the database established above.
      0 * * * * rrdtool graph /home/pi/MagicMirror/modules/cputemp.gif --start -24h --title "CPU-Temperatur" --vertical-label "Grad Celsius" --disable-rrdtool-tag DEF:cputemperatur=cputemp.rrd:temp:AVERAGE LINE1:cputemperatur#ff0000:"CPU-Temperatur" ;
      generates once in an hour a graph which will be displayed later. If you like, you can adjust the map legend (“CPU-Temperatur” and “Grad Celsius”) with descriptions in your language.
      Now create a file named cputemp.html in the modules-folder of your MM:
      <HTML>
      <HEAD>
      <TITLE>CPU Temperatur</TITLE>
      </HEAD>
      <body bgcolor=#000000>
      	<img src="cputemp.gif"/>
      </body>
      </HTML>
      and use MMM-SmartWebDisplay in your config.js to show it:
      			disabled: false,
      			module: 'MMM-SmartWebDisplay',
      			position: 'top_center',
      				logDebug: false,
      				height: "180",
      				width:"500",
      				updateInterval: 0,
      				NextURLInterval: 0,
      				displayLastUpdate: false,
      				url: ["/modules/cputemp.html"],
      Based on these steps, some more modifications of the appearance are possible. Please use your favorite search-engine for more.
      • thgmirrorT thgmirror referenced this topic on
