    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 15.5k Views 4 Watching
    • karsten13K Online
      karsten13 @Snille
      @Snille
      if you can manage to insert http://localhost:8080/cors?url= so that the whole url is http://localhost:8080/cors?url=http://10.0.0.249: ... it should work
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @karsten13
        @karsten13 Almost… I can’t use “localhost” because then I cant access the “remote control” (and therefore can not open DevTools) from anywhere… So I have to set at least the “IP” of the mirror… But I still get the broken image…
        But I get no errors in the console now… Hmm…
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        • karsten13K Online
          karsten13 @Snille
          @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
          strange, may errors in the server logs?
          SnilleS 2 Replies Last reply Reply Quote 0
          • SnilleS Offline
            @karsten13 in the (pm2 log) I get:
            0|MagicMirror  | [11.04.2022 23:30.43.266] [LOG]
            0|MagicMirror  | cors url: http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=5b341e663bd99335792031e6f0129db5502c3eddfc4e297f70bdbfbc284a528e
            For every try. Now it no longer works in the browser… And if I curl it…
            curl -sL http://10.0.0.112:8080/cors?url=http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=562f09c026b6a8a87de4dc0ed7bfe5273e23429c1fb152be3597c37cf1b6d2d0
            I get nothing… :)
            So, something is not working more now… :)
            • karsten13K Online
              karsten13 @Snille
              @Snille
              the cors url log entry is o.k., but no idea at the moment. I’m not sure if the ip (instead of localhost) works, will try to test this tomorrow (I have no homeassistant so this will be no real test) …
              • SnilleS Offline
                Hang on, I just reset everything “back”, reset the MMM-homeassistant-sensors
                to it’s “original” state but let the IP be set in the config… And now it works?
                What’s going on here?! :)
                All modules that are fetching pictures from other places are now working!?
                So, the config needs to have the actual IP of the mirror set now. I have been using 0.0.0.0 all the time… Also tried “localhost” and it did not work. But the actual IP works!
                Great!! Thank you all for helping out! :)
                • W Offline
                  wmx
                  Ok, I can reproduce this correction too! :-)
                  After changing address: “0.0.0.0” to the real ip address: “192.168.x.y” and removing every additional config from this thread ALL images are back again!
                  Thank you all for this simple but effictive solution!
                    borrmi
                    Yep! changing “0.0.0.0” to “192.168.x.x” solved the problem and pictures are shown! Thanks to everybody!
                    • 4 / 4
