    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 18.7k Views 4 Watching
    • SnilleS
      Snille Module Developer @sdetweil
      @sdetweil Correct, and in a normal browser it works. And for me, the “person.sensor” works too (now?)…
      Anyway, here you have the “Map-extract” from HA, also using my module for showing the picture of the vacuum-map… In the browser it works, on the Mirror it does not… :)
      Browser:
      Mirror:
      Here is “part” of the extract object (including the picture):
                  "model": "roborock.vacuum.s5",
                  "used_api": "xiaomi",
                  "entity_picture": "/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=1e870c95e944a30b0731ae4b3a3bc8dsf65231b6ba03fd91d8s96af38d05c6ce",
                  "friendly_name": "Xiaomi Cloud Map Extractor",
                  "supported_features": 1
      For some reson the Browser works… Confused yet? :)
      • W
        wmx
        @sdetweil, @Snille
        same here.
        The urls to the icons work in browser sessions showing MM, but do not work local in raspi with MM.
        I tested access from raspi console with
        curl -sL http://<ma-ha-url>:8123/local/images/person.jpg >person.jpg
        and this works too.
        I also have the same problem, the local MM is not able to access a remote_compliments.conf file via URL in the local module\defaults\compliments folder, but I can access it from a browser. Seems to be the same problem!?
          sdetweil @Snille
          @Snille what is the view of the console in the MM dev window? should be an access error
          SnilleS 1 Reply Last reply
          • SnilleS
            @sdetweil Correct, it’s the cors error:
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @Snille
              @Snille
              if you can manage to insert http://localhost:8080/cors?url= so that the whole url is http://localhost:8080/cors?url=http://10.0.0.249: ... it should work
              • SnilleS
                Snille Module Developer @karsten13
                @karsten13 Almost… I can’t use “localhost” because then I cant access the “remote control” (and therefore can not open DevTools) from anywhere… So I have to set at least the “IP” of the mirror… But I still get the broken image…
                But I get no errors in the console now… Hmm…
                • karsten13K
                  karsten13 @Snille
                  @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                  strange, may errors in the server logs?
                  SnilleS 2 Replies Last reply
                  • SnilleS
                    @karsten13 in the (pm2 log) I get:
                    0|MagicMirror  | [11.04.2022 23:30.43.266] [LOG]
                    0|MagicMirror  | cors url: http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=5b341e663bd99335792031e6f0129db5502c3eddfc4e297f70bdbfbc284a528e
                    For every try. Now it no longer works in the browser… And if I curl it…
                    curl -sL http://10.0.0.112:8080/cors?url=http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=562f09c026b6a8a87de4dc0ed7bfe5273e23429c1fb152be3597c37cf1b6d2d0
                    I get nothing… :)
                    So, something is not working more now… :)
                    • karsten13K
                      karsten13 @Snille
                      @Snille
                      the cors url log entry is o.k., but no idea at the moment. I’m not sure if the ip (instead of localhost) works, will try to test this tomorrow (I have no homeassistant so this will be no real test) …
                      • SnilleS
                        Hang on, I just reset everything “back”, reset the MMM-homeassistant-sensors
                        to it’s “original” state but let the IP be set in the config… And now it works?
                        What’s going on here?! :)
                        All modules that are fetching pictures from other places are now working!?
                        So, the config needs to have the actual IP of the mirror set now. I have been using 0.0.0.0 all the time… Also tried “localhost” and it did not work. But the actual IP works!
                        Great!! Thank you all for helping out! :)
                        • W
                          wmx
                          Ok, I can reproduce this correction too! :-)
                          After changing address: “0.0.0.0” to the real ip address: “192.168.x.y” and removing every additional config from this thread ALL images are back again!
                          Thank you all for this simple but effictive solution!
                            borrmi
                            Yep! changing “0.0.0.0” to “192.168.x.x” solved the problem and pictures are shown! Thanks to everybody!
