    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 17.9k Views 4 Watching
      sdetweil @borrmi
      @borrmi u replaced ha_url with the right value, correct?
        borrmi @sdetweil
        @sdetweil yes. My ha is under 192.168.2.100 and reachable via Browser(8123) and also in ssh
          sdetweil @borrmi
          @borrmi ok, I just copy/pasted your url…
          if it says 404, then thats the wrong URL to get the image
          http://192.168.2.100:8123/
          is right… its the rest that is not
            borrmi @sdetweil
            i checked the ha path via ssh
            the pictures are in /media.
            should i put them in another directory (e.g. /home/borrmi/pictures)
              sdetweil @borrmi
              @borrmi i have no idea where ha server makes them available to outside the ha machine consumers…
              what did u have before this latest MM update?
                borrmi
                nothing, it is a new installation. first time with a running ha instance in the house
                funfact:
                in a browser on my pc i can see the pictures with only
                                            sensor: "person.borrmi",
                                            name: "Borrmi ist %v%",
                                            displayvalue: false,
                                            replace: [{
                                                            "home": "zu Hause",
                                                            "not_home": "nicht zu Hause",
                  @borrmi ok never ha for me
                  that is the image definitions, what to use for what…
                  but not the image itself, which is what mm needs
                  I don’t know if u request it by name (sensor) or filename (person.borrmi)
                  B SnilleS 2 Replies Last reply Reply Quote 0
                    borrmi @sdetweil
                    @sdetweil person.borrmi ist a sensor
                    • SnilleS Offline
                      Snille Module Developer @sdetweil
                      @sdetweil This is what you get back (as a picture) from HA when adding a person as a sensor looks like this:
                      https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512
                      So, before “cors” I just did:
                      <img src="https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512" class="ha-img">
                      And it worked (still does in a browser), but not on the mirror.
                      The whole “person”-object looks like this:
                          "entity_id": "person.firstname_lastname",
                          "state": "at Some Place",
                          "attributes": {
                              "editable": false,
                              "id": "9cd6gj3a4eb8ds4d0bfd2b0e1e57804ea",
                              "latitude": 16.1241928,
                              "longitude": 82.9718906,
                              "gps_accuracy": 18,
                              "source": "device_tracker.google_maps_105082325327346729172",
                              "user_id": "402df0jd89b84230bf8fe3g7ff653048",
                              "entity_picture": "/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512",
                              "friendly_name": "FirstName LastName"
                          "last_changed": "2022-04-11T18:17:53.738567+00:00",
                          "last_updated": "2022-04-11T19:53:55.043510+00:00",
                          "context": {
                              "id": "2489fb6bas56fgdds142155e5668093a28",
                              "parent_id": null,
                              "user_id": null
                      Don’t know if this helps… :)
                        sdetweil @Snille
                        @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                        “entity_picture”: “/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512”
                        right, there is the url to use
                        SnilleS 1 Reply Last reply Reply Quote 0
                        • SnilleS Offline
                          @sdetweil Correct, and in a normal browser it works. And for me, the “person.sensor” works too (now?)…
                          Anyway, here you have the “Map-extract” from HA, also using my module for showing the picture of the vacuum-map… In the browser it works, on the Mirror it does not… :)
                          Browser:
                          Mirror:
                          Here is “part” of the extract object (including the picture):
                                      "model": "roborock.vacuum.s5",
                                      "used_api": "xiaomi",
                                      "entity_picture": "/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=1e870c95e944a30b0731ae4b3a3bc8dsf65231b6ba03fd91d8s96af38d05c6ce",
                                      "friendly_name": "Xiaomi Cloud Map Extractor",
                                      "supported_features": 1
                          For some reson the Browser works… Confused yet? :)
                          • W Offline
                            wmx
                            @sdetweil, @Snille
                            same here.
                            The urls to the icons work in browser sessions showing MM, but do not work local in raspi with MM.
                            I tested access from raspi console with
                            curl -sL http://<ma-ha-url>:8123/local/images/person.jpg >person.jpg
                            and this works too.
                            I also have the same problem, the local MM is not able to access a remote_compliments.conf file via URL in the local module\defaults\compliments folder, but I can access it from a browser. Seems to be the same problem!?
                              sdetweil @Snille
                              @Snille what is the view of the console in the MM dev window? should be an access error
                              • SnilleS Offline
                                @sdetweil Correct, it’s the cors error:
                                • karsten13K Offline
                                  karsten13 @Snille
                                  @Snille
                                  if you can manage to insert http://localhost:8080/cors?url= so that the whole url is http://localhost:8080/cors?url=http://10.0.0.249: ... it should work
                                  • SnilleS Offline
                                    Snille Module Developer @karsten13
                                    @karsten13 Almost… I can’t use “localhost” because then I cant access the “remote control” (and therefore can not open DevTools) from anywhere… So I have to set at least the “IP” of the mirror… But I still get the broken image…
                                    But I get no errors in the console now… Hmm…
                                      karsten13 @Snille
                                      strange, may errors in the server logs?
                                      • SnilleS Offline
                                        @karsten13 in the (pm2 log) I get:
                                        0|MagicMirror  | [11.04.2022 23:30.43.266] [LOG]
                                        0|MagicMirror  | cors url: http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=5b341e663bd99335792031e6f0129db5502c3eddfc4e297f70bdbfbc284a528e
                                        For every try. Now it no longer works in the browser… And if I curl it…
                                        curl -sL http://10.0.0.112:8080/cors?url=http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=562f09c026b6a8a87de4dc0ed7bfe5273e23429c1fb152be3597c37cf1b6d2d0
                                        I get nothing… :)
                                        So, something is not working more now… :)
                                          karsten13 @Snille
                                          @Snille
                                          the cors url log entry is o.k., but no idea at the moment. I’m not sure if the ip (instead of localhost) works, will try to test this tomorrow (I have no homeassistant so this will be no real test) …
                                          • SnilleS Offline
                                            Hang on, I just reset everything “back”, reset the MMM-homeassistant-sensors
                                            to it’s “original” state but let the IP be set in the config… And now it works?
                                            What’s going on here?! :)
                                            All modules that are fetching pictures from other places are now working!?
                                            So, the config needs to have the actual IP of the mirror set now. I have been using 0.0.0.0 all the time… Also tried “localhost” and it did not work. But the actual IP works!
                                            Great!! Thank you all for helping out! :)
