    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 18.7k Views 4 Watching
      sdetweil @borrmi
      @borrmi said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
      http://ha_url:8123/media/borrmi.png
      does that work from a browser or curl on the system running MagicMirror?
      curl -sL http://ha_url:8123/media/borrmi.png >borrmi.png
      B 1 Reply Last reply
        borrmi @sdetweil
        @sdetweil said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
        no “404: Not Found”
          sdetweil @borrmi
          @borrmi u replaced ha_url with the right value, correct?
            borrmi @sdetweil
            @sdetweil yes. My ha is under 192.168.2.100 and reachable via Browser(8123) and also in ssh
              sdetweil @borrmi
              @borrmi ok, I just copy/pasted your url…
              if it says 404, then thats the wrong URL to get the image
              http://192.168.2.100:8123/
              is right… its the rest that is not
                borrmi @sdetweil
                i checked the ha path via ssh
                the pictures are in /media.
                should i put them in another directory (e.g. /home/borrmi/pictures)
                  sdetweil @borrmi
                  @borrmi i have no idea where ha server makes them available to outside the ha machine consumers…
                  what did u have before this latest MM update?
                    borrmi
                    nothing, it is a new installation. first time with a running ha instance in the house
                    funfact:
                    in a browser on my pc i can see the pictures with only
                                                sensor: "person.borrmi",
                                                name: "Borrmi ist %v%",
                                                displayvalue: false,
                                                replace: [{
        "home": "zu Hause",
        "not_home": "nicht zu Hause",
                      @borrmi ok never ha for me
                      that is the image definitions, what to use for what…
                      but not the image itself, which is what mm needs
                      I don’t know if u request it by name (sensor) or filename (person.borrmi)
                      B SnilleS 2 Replies Last reply
                        borrmi @sdetweil
                        @sdetweil person.borrmi ist a sensor
                        • SnilleS
                          Snille Module Developer @sdetweil
                          @sdetweil This is what you get back (as a picture) from HA when adding a person as a sensor looks like this:
                          https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512
                          So, before “cors” I just did:
                          <img src="https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512" class="ha-img">
                          And it worked (still does in a browser), but not on the mirror.
                          The whole “person”-object looks like this:
                              "entity_id": "person.firstname_lastname",
                              "state": "at Some Place",
                              "attributes": {
                                  "editable": false,
                                  "id": "9cd6gj3a4eb8ds4d0bfd2b0e1e57804ea",
                                  "latitude": 16.1241928,
                                  "longitude": 82.9718906,
                                  "gps_accuracy": 18,
                                  "source": "device_tracker.google_maps_105082325327346729172",
                                  "user_id": "402df0jd89b84230bf8fe3g7ff653048",
                                  "entity_picture": "/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512",
                                  "friendly_name": "FirstName LastName"
                              "last_changed": "2022-04-11T18:17:53.738567+00:00",
                              "last_updated": "2022-04-11T19:53:55.043510+00:00",
                              "context": {
                                  "id": "2489fb6bas56fgdds142155e5668093a28",
                                  "parent_id": null,
                                  "user_id": null
                          Don’t know if this helps… :)
                            sdetweil @Snille
                            @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                            “entity_picture”: “/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512”
                            right, there is the url to use
                            SnilleS 1 Reply Last reply
                            • SnilleS
                              @sdetweil Correct, and in a normal browser it works. And for me, the “person.sensor” works too (now?)…
                              Anyway, here you have the “Map-extract” from HA, also using my module for showing the picture of the vacuum-map… In the browser it works, on the Mirror it does not… :)
                              Browser:
                              Mirror:
                              Here is “part” of the extract object (including the picture):
                                          "model": "roborock.vacuum.s5",
                                          "used_api": "xiaomi",
                                          "entity_picture": "/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=1e870c95e944a30b0731ae4b3a3bc8dsf65231b6ba03fd91d8s96af38d05c6ce",
                                          "friendly_name": "Xiaomi Cloud Map Extractor",
                                          "supported_features": 1
                              For some reson the Browser works… Confused yet? :)
                              • W
                                wmx
                                @sdetweil, @Snille
                                same here.
                                The urls to the icons work in browser sessions showing MM, but do not work local in raspi with MM.
                                I tested access from raspi console with
                                curl -sL http://<ma-ha-url>:8123/local/images/person.jpg >person.jpg
                                and this works too.
                                I also have the same problem, the local MM is not able to access a remote_compliments.conf file via URL in the local module\defaults\compliments folder, but I can access it from a browser. Seems to be the same problem!?
                                  sdetweil @Snille
                                  @Snille what is the view of the console in the MM dev window? should be an access error
                                  • SnilleS
                                    @sdetweil Correct, it’s the cors error:
                                    karsten13K 1 Reply Last reply
                                    • karsten13K
                                      karsten13 @Snille
                                      @Snille
                                      if you can manage to insert http://localhost:8080/cors?url= so that the whole url is http://localhost:8080/cors?url=http://10.0.0.249: ... it should work
                                      • SnilleS
                                        Snille Module Developer @karsten13
                                        @karsten13 Almost… I can’t use “localhost” because then I cant access the “remote control” (and therefore can not open DevTools) from anywhere… So I have to set at least the “IP” of the mirror… But I still get the broken image…
                                        But I get no errors in the console now… Hmm…
                                        • karsten13K
                                          karsten13 @Snille
                                          strange, may errors in the server logs?
                                          • SnilleS
                                            @karsten13 in the (pm2 log) I get:
                                            0|MagicMirror  | [11.04.2022 23:30.43.266] [LOG]
                                            0|MagicMirror  | cors url: http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=5b341e663bd99335792031e6f0129db5502c3eddfc4e297f70bdbfbc284a528e
                                            For every try. Now it no longer works in the browser… And if I curl it…
                                            curl -sL http://10.0.0.112:8080/cors?url=http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=562f09c026b6a8a87de4dc0ed7bfe5273e23429c1fb152be3597c37cf1b6d2d0
                                            I get nothing… :)
                                            So, something is not working more now… :)
