    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 18.4k Views 4 Watching
    • W
      wmx
      Hi everyone,
      our MM was running like a charm with 2.18.0 and MMM-homeassistant-sensors from @snille showing our family members and fuel prices with the icons configured in Home Assistant.
      After the upgrade to 2.19.0 (and some manual tweaks with other modules) everything is up and running again, but the same elements provided by ha as before do not show up any icons (in fromt of the entries!). At the moment it looks like this:
      Normally there should be pictures from our family members and logos from the fuel stations and all comes from ha.
      Is there a way to fix this?
      What more infos do you need to find what’s going wrong here?
      Any help welcome.
      Regards
      karsten13K SnilleS 2 Replies Last reply Reply Quote 0
      • W
        wmx
        Ok, I can reproduce this correction too! :-)
        After changing address: “0.0.0.0” to the real ip address: “192.168.x.y” and removing every additional config from this thread ALL images are back again!
        Thank you all for this simple but effictive solution!
        • karsten13K
          karsten13 @wmx
          @wmx said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
          may a cors problem, are there any errors in the console?
          I assume you are running this on a pi, can you test if this works in a browser http://<ip-address-of-the-pi>:8080 ?
            sdetweil @karsten13
            @karsten13 on a desktop??
            • SnilleS
              Snille Module Developer @wmx
              @wmx Hi, this has to do with “cors”, it’s not allowed anymore to load the pictures the way I do it, I have to rewrite stuff to fix it, I just don’t have the time… I’m currently loading the pictures form “internet” using a URL instead… It works, but not as nice as geting them from HA…
              Like this:
              values: [
              		sensor: "person.jane_doe",
              		name: "Jane are %v%",
              		displayvalue: false,
              		icons: [{
              			"default": "https://www.snille.net/img/magicmirror/users/jane.png"
              karsten13K B 2 Replies Last reply Reply Quote 0
              • karsten13K
                karsten13 @Snille
                @Snille
                can you test "default": location.protocol + "//" + location.host + "/cors?url=" + old_ha_url ?
                Since v2.19.0 there is a cors proxy inside mm which is used in the weather module and can be used by every other module.
                SnilleS 1 Reply Last reply Reply Quote 0
                • SnilleS
                  Snille Module Developer @karsten13
                  @karsten13 Oh! I did not know that… I’m guessing this has to be done in the actual module somewhere? I have to see if I can figure it out. :)
                  • karsten13K
                    karsten13 @Snille
                    @Snille works only with latest mm release, you can test this before coding with "default": "http://localhost:8080/cors?url=http://your_not_working_url" (you have to adjust params to https or other port if necassary).
                    You find the corresponding PR here.
                    • SnilleS
                      @karsten13 Hm… Not sure if that works, the “picture” is different depending om what the “sensor” is sending, so it’s not possible to set the “url=http://your_not_working_url” to something static… I’ll have to read up on it… :) Thank you!
                        sdetweil @Snille
                        @Snille you should be able to see the CORS error in the dev window.
                        however the url gets built now for the image, should be able to change it
                        • W
                          wmx
                          @karsten13 , @Snille
                          Sorry for the delay, but hanks for your feedback.
                          Yes, I’m running MM on a raspi 3.
                          One more point I figured out:
                          The display connected to the raspi an showing THE mm on the wall has these problems with missing images.
                          If I connect with a browser from my desltop to the mm URL the images are visible.
                          I’ll try to test your given notes this weekend and return the results back here.
                          • W
                            wmx
                            @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                              icons: [{
                            (think in the example there is one closing bracket missing “]”)
                            Had the time right now to test this one issue. I insertet the URL to the image from ha :-) (which is a static one here)
                            http://<my-ha-url>:8123/local/images/hem.png
                            but after restart of MM the problem still exists.
                            • karsten13K
                              karsten13 @wmx
                              @wmx
                              should be
                              icons: [{
                                "default": "http://localhost:8080/cors?url=http://<my-ha-url>:8123/local/images/hem.png"
                              • W
                                wmx
                                @karsten13
                                Ok, tried this new config, but it does not change anything. :-(
                                  borrmi @Snille
                                  @karsten13
                                  I tried this(in the brackets)
                                  default": "http://mm_url:8080/cors?url=http://ha_url:8123/media/borrmi.png but this doesn’t work. :-(
                                  can i also use a local path on my mm instead? (e.g. ‘~/MagicMirror/pictures/person.png’)
                                    sdetweil @borrmi
                                    @borrmi said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                                    does that work from a browser or curl on the system running MagicMirror?
                                    curl -sL http://ha_url:8123/media/borrmi.png >borrmi.png
                                      borrmi @sdetweil
                                      @sdetweil said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                                      no “404: Not Found”
                                        sdetweil @borrmi
                                        @borrmi u replaced ha_url with the right value, correct?
                                          borrmi @sdetweil
                                          @sdetweil yes. My ha is under 192.168.2.100 and reachable via Browser(8123) and also in ssh
                                            sdetweil @borrmi
                                            @borrmi ok, I just copy/pasted your url…
                                            if it says 404, then thats the wrong URL to get the image
                                            http://192.168.2.100:8123/
                                            is right… its the rest that is not
                                              borrmi @sdetweil
                                              i checked the ha path via ssh
                                              the pictures are in /media.
                                              should i put them in another directory (e.g. /home/borrmi/pictures)
