    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 15.0k Views 4 Watching
      sdetweil @karsten13
      @karsten13 on a desktop??
      • SnilleS Offline
        Snille Module Developer @wmx
        @wmx Hi, this has to do with “cors”, it’s not allowed anymore to load the pictures the way I do it, I have to rewrite stuff to fix it, I just don’t have the time… I’m currently loading the pictures form “internet” using a URL instead… It works, but not as nice as geting them from HA…
        Like this:
        values: [
        		sensor: "person.jane_doe",
        		name: "Jane are %v%",
        		displayvalue: false,
        		icons: [{
        			"default": "https://www.snille.net/img/magicmirror/users/jane.png"
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        karsten13K B 2 Replies Last reply Reply Quote 0
        • karsten13K Offline
          karsten13 @Snille
          @Snille
          can you test "default": location.protocol + "//" + location.host + "/cors?url=" + old_ha_url ?
          Since v2.19.0 there is a cors proxy inside mm which is used in the weather module and can be used by every other module.
          SnilleS 1 Reply Last reply Reply Quote 0
          • SnilleS Offline
            Snille Module Developer @karsten13
            @karsten13 Oh! I did not know that… I’m guessing this has to be done in the actual module somewhere? I have to see if I can figure it out. :)
              karsten13 @Snille
              @Snille works only with latest mm release, you can test this before coding with "default": "http://localhost:8080/cors?url=http://your_not_working_url" (you have to adjust params to https or other port if necassary).
              You find the corresponding PR here.
              • SnilleS Offline
                @karsten13 Hm… Not sure if that works, the “picture” is different depending om what the “sensor” is sending, so it’s not possible to set the “url=http://your_not_working_url” to something static… I’ll have to read up on it… :) Thank you!
                  sdetweil @Snille
                  @Snille you should be able to see the CORS error in the dev window.
                  however the url gets built now for the image, should be able to change it
                  • W Offline
                    wmx
                    @karsten13 , @Snille
                    Sorry for the delay, but hanks for your feedback.
                    Yes, I’m running MM on a raspi 3.
                    One more point I figured out:
                    The display connected to the raspi an showing THE mm on the wall has these problems with missing images.
                    If I connect with a browser from my desltop to the mm URL the images are visible.
                    I’ll try to test your given notes this weekend and return the results back here.
                    • W Offline
                      wmx
                      @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                        icons: [{
                      (think in the example there is one closing bracket missing “]”)
                      Had the time right now to test this one issue. I insertet the URL to the image from ha :-) (which is a static one here)
                      http://<my-ha-url>:8123/local/images/hem.png
                      but after restart of MM the problem still exists.
                        karsten13 @wmx
                        @wmx
                        should be
                        icons: [{
                          "default": "http://localhost:8080/cors?url=http://<my-ha-url>:8123/local/images/hem.png"
                        • 1 / 4
