    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 18.7k Views 4 Watching
    • karsten13K
      karsten13 @Snille
      @Snille
      can you test "default": location.protocol + "//" + location.host + "/cors?url=" + old_ha_url ?
      Since v2.19.0 there is a cors proxy inside mm which is used in the weather module and can be used by every other module.
      SnilleS 1 Reply Last reply
      • SnilleS
        Snille Module Developer @karsten13
        @karsten13 Oh! I did not know that… I’m guessing this has to be done in the actual module somewhere? I have to see if I can figure it out. :)
        karsten13K 1 Reply Last reply
        • karsten13K
          karsten13 @Snille
          @Snille works only with latest mm release, you can test this before coding with "default": "http://localhost:8080/cors?url=http://your_not_working_url" (you have to adjust params to https or other port if necassary).
          You find the corresponding PR here.
          • SnilleS
            @karsten13 Hm… Not sure if that works, the “picture” is different depending om what the “sensor” is sending, so it’s not possible to set the “url=http://your_not_working_url” to something static… I’ll have to read up on it… :) Thank you!
              sdetweil @Snille
              @Snille you should be able to see the CORS error in the dev window.
              however the url gets built now for the image, should be able to change it
              • W
                wmx
                @karsten13 , @Snille
                Sorry for the delay, but hanks for your feedback.
                Yes, I’m running MM on a raspi 3.
                One more point I figured out:
                The display connected to the raspi an showing THE mm on the wall has these problems with missing images.
                If I connect with a browser from my desltop to the mm URL the images are visible.
                I’ll try to test your given notes this weekend and return the results back here.
                • W
                  wmx
                  @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                    icons: [{
                    	"default": "https://www.snille.net/img/magicmirror/users/jane.png"
                  (think in the example there is one closing bracket missing “]”)
                  Had the time right now to test this one issue. I insertet the URL to the image from ha :-) (which is a static one here)
                  http://<my-ha-url>:8123/local/images/hem.png
                  but after restart of MM the problem still exists.
                  • karsten13K
                    karsten13 @wmx
                    @wmx
                    should be
                    icons: [{
                      "default": "http://localhost:8080/cors?url=http://<my-ha-url>:8123/local/images/hem.png"
                    • W
                      wmx
                      @karsten13
                      Ok, tried this new config, but it does not change anything. :-(
                        borrmi @Snille
                        @karsten13
                        I tried this(in the brackets)
                        default": "http://mm_url:8080/cors?url=http://ha_url:8123/media/borrmi.png but this doesn’t work. :-(
                        can i also use a local path on my mm instead? (e.g. ‘~/MagicMirror/pictures/person.png’)
                          sdetweil @borrmi
                          @borrmi said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                          does that work from a browser or curl on the system running MagicMirror?
                          curl -sL http://ha_url:8123/media/borrmi.png >borrmi.png
                          B 1 Reply Last reply
                            borrmi @sdetweil
                            @sdetweil said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                            no “404: Not Found”
                              sdetweil @borrmi
                              @borrmi u replaced ha_url with the right value, correct?
                                borrmi @sdetweil
                                @sdetweil yes. My ha is under 192.168.2.100 and reachable via Browser(8123) and also in ssh
                                  sdetweil @borrmi
                                  @borrmi ok, I just copy/pasted your url…
                                  if it says 404, then thats the wrong URL to get the image
                                  http://192.168.2.100:8123/
                                  is right… its the rest that is not
                                    borrmi @sdetweil
                                    i checked the ha path via ssh
                                    the pictures are in /media.
                                    should i put them in another directory (e.g. /home/borrmi/pictures)
                                      sdetweil @borrmi
                                      @borrmi i have no idea where ha server makes them available to outside the ha machine consumers…
                                      what did u have before this latest MM update?
                                        borrmi
                                        nothing, it is a new installation. first time with a running ha instance in the house
                                        funfact:
                                        in a browser on my pc i can see the pictures with only
        sensor: "person.borrmi",
        name: "Borrmi ist %v%",
        displayvalue: false,
        replace: [{
        "home": "zu Hause",
        "not_home": "nicht zu Hause",
                                          @borrmi ok never ha for me
                                          that is the image definitions, what to use for what…
                                          but not the image itself, which is what mm needs
                                          I don’t know if u request it by name (sensor) or filename (person.borrmi)
                                          B SnilleS 2 Replies Last reply
                                            borrmi @sdetweil
                                            @sdetweil person.borrmi ist a sensor
