    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 18.4k Views 4 Watching
    • karsten13K
      karsten13 @wmx
      @wmx said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
      What more infos do you need to find what’s going wrong here?
      may a cors problem, are there any errors in the console?
      I assume you are running this on a pi, can you test if this works in a browser http://<ip-address-of-the-pi>:8080 ?
        sdetweil @karsten13
        @karsten13 on a desktop??
        • SnilleS
          Snille Module Developer @wmx
          @wmx Hi, this has to do with “cors”, it’s not allowed anymore to load the pictures the way I do it, I have to rewrite stuff to fix it, I just don’t have the time… I’m currently loading the pictures form “internet” using a URL instead… It works, but not as nice as geting them from HA…
          Like this:
          values: [
          		sensor: "person.jane_doe",
          		name: "Jane are %v%",
          		displayvalue: false,
          		icons: [{
          			"default": "https://www.snille.net/img/magicmirror/users/jane.png"
          karsten13K B 2 Replies Last reply
          • karsten13K
            karsten13 @Snille
            @Snille
            can you test "default": location.protocol + "//" + location.host + "/cors?url=" + old_ha_url ?
            Since v2.19.0 there is a cors proxy inside mm which is used in the weather module and can be used by every other module.
            SnilleS 1 Reply Last reply
            • SnilleS
              Snille Module Developer @karsten13
              @karsten13 Oh! I did not know that… I’m guessing this has to be done in the actual module somewhere? I have to see if I can figure it out. :)
              karsten13K 1 Reply Last reply
              • karsten13K
                karsten13 @Snille
                @Snille works only with latest mm release, you can test this before coding with "default": "http://localhost:8080/cors?url=http://your_not_working_url" (you have to adjust params to https or other port if necassary).
                You find the corresponding PR here.
                • SnilleS
                  @karsten13 Hm… Not sure if that works, the “picture” is different depending om what the “sensor” is sending, so it’s not possible to set the “url=http://your_not_working_url” to something static… I’ll have to read up on it… :) Thank you!
                    sdetweil @Snille
                    @Snille you should be able to see the CORS error in the dev window.
                    however the url gets built now for the image, should be able to change it
                    • W
                      wmx
                      @karsten13 , @Snille
                      Sorry for the delay, but hanks for your feedback.
                      Yes, I’m running MM on a raspi 3.
                      One more point I figured out:
                      The display connected to the raspi an showing THE mm on the wall has these problems with missing images.
                      If I connect with a browser from my desltop to the mm URL the images are visible.
                      I’ll try to test your given notes this weekend and return the results back here.
                      • W
                        wmx
                        @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                          icons: [{
                        (think in the example there is one closing bracket missing “]”)
                        Had the time right now to test this one issue. I insertet the URL to the image from ha :-) (which is a static one here)
                        http://<my-ha-url>:8123/local/images/hem.png
                        but after restart of MM the problem still exists.
                        • karsten13K
                          karsten13 @wmx
                          @wmx
                          should be
                          icons: [{
                            "default": "http://localhost:8080/cors?url=http://<my-ha-url>:8123/local/images/hem.png"
                          • W
                            wmx
                            @karsten13
                            Ok, tried this new config, but it does not change anything. :-(
                              borrmi @Snille
                              @karsten13
                              I tried this(in the brackets)
                              default": "http://mm_url:8080/cors?url=http://ha_url:8123/media/borrmi.png but this doesn’t work. :-(
                              can i also use a local path on my mm instead? (e.g. ‘~/MagicMirror/pictures/person.png’)
                                sdetweil @borrmi
                                @borrmi said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                                does that work from a browser or curl on the system running MagicMirror?
                                curl -sL http://ha_url:8123/media/borrmi.png >borrmi.png
                                B 1 Reply Last reply
                                  borrmi @sdetweil
                                  @sdetweil said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                                  no “404: Not Found”
                                    sdetweil @borrmi
                                    @borrmi u replaced ha_url with the right value, correct?
                                      borrmi @sdetweil
                                      @sdetweil yes. My ha is under 192.168.2.100 and reachable via Browser(8123) and also in ssh
                                        sdetweil @borrmi
                                        @borrmi ok, I just copy/pasted your url…
                                        if it says 404, then thats the wrong URL to get the image
                                        http://192.168.2.100:8123/
                                        is right… its the rest that is not
                                          borrmi @sdetweil
                                          i checked the ha path via ssh
                                          the pictures are in /media.
                                          should i put them in another directory (e.g. /home/borrmi/pictures)
                                            sdetweil @borrmi
                                            @borrmi i have no idea where ha server makes them available to outside the ha machine consumers…
                                            what did u have before this latest MM update?
