    MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0
    38 Posts 5 Posters 16.7k Views 4 Watching
      sdetweil @borrmi
      @borrmi i have no idea where ha server makes them available to outside the ha machine consumers…
      what did u have before this latest MM update?
        borrmi
        nothing, it is a new installation. first time with a running ha instance in the house
        funfact:
        in a browser on my pc i can see the pictures with only
                                    sensor: "person.borrmi",
                                    name: "Borrmi ist %v%",
                                    displayvalue: false,
                                    replace: [{
                                                    "home": "zu Hause",
                                                    "not_home": "nicht zu Hause",
          sdetweil
          @borrmi ok never ha for me
          that is the image definitions, what to use for what…
          but not the image itself, which is what mm needs
          I don’t know if u request it by name (sensor) or filename (person.borrmi)
          B SnilleS 2 Replies Last reply Reply Quote 0
            borrmi @sdetweil
            @sdetweil person.borrmi ist a sensor
            • SnilleS Offline
              Snille Module Developer @sdetweil
              @sdetweil This is what you get back (as a picture) from HA when adding a person as a sensor looks like this:
              https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512
              So, before “cors” I just did:
              <img src="https://your.haipaddress.here:443/api/image/serve/d5b50f6cf5e15d2e1d3f5457293458f6/512x512" class="ha-img">
              And it worked (still does in a browser), but not on the mirror.
              The whole “person”-object looks like this:
                  "entity_id": "person.firstname_lastname",
                  "state": "at Some Place",
                  "attributes": {
                      "editable": false,
                      "id": "9cd6gj3a4eb8ds4d0bfd2b0e1e57804ea",
                      "latitude": 16.1241928,
                      "longitude": 82.9718906,
                      "gps_accuracy": 18,
                      "source": "device_tracker.google_maps_105082325327346729172",
                      "user_id": "402df0jd89b84230bf8fe3g7ff653048",
                      "entity_picture": "/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512",
                      "friendly_name": "FirstName LastName"
                  "last_changed": "2022-04-11T18:17:53.738567+00:00",
                  "last_updated": "2022-04-11T19:53:55.043510+00:00",
                  "context": {
                      "id": "2489fb6bas56fgdds142155e5668093a28",
                      "parent_id": null,
                      "user_id": null
              Don’t know if this helps… :)
              If you cant find it, make it and share it
              MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                sdetweil @Snille
                @Snille said in MMM-homeassistant-sensors no icons after MM upgrade to 2.19.0:
                “entity_picture”: “/api/image/serve/a2dc96037s5b9dg86s4cc6336b62d742/512x512”
                right, there is the url to use
                SnilleS 1 Reply Last reply Reply Quote 0
                • SnilleS Offline
                  @sdetweil Correct, and in a normal browser it works. And for me, the “person.sensor” works too (now?)…
                  Anyway, here you have the “Map-extract” from HA, also using my module for showing the picture of the vacuum-map… In the browser it works, on the Mirror it does not… :)
                  Browser:
                  Mirror:
                  Here is “part” of the extract object (including the picture):
                              "model": "roborock.vacuum.s5",
                              "used_api": "xiaomi",
                              "entity_picture": "/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=1e870c95e944a30b0731ae4b3a3bc8dsf65231b6ba03fd91d8s96af38d05c6ce",
                              "friendly_name": "Xiaomi Cloud Map Extractor",
                              "supported_features": 1
                  For some reson the Browser works… Confused yet? :)
                  • W Offline
                    wmx
                    @sdetweil, @Snille
                    same here.
                    The urls to the icons work in browser sessions showing MM, but do not work local in raspi with MM.
                    I tested access from raspi console with
                    curl -sL http://<ma-ha-url>:8123/local/images/person.jpg >person.jpg
                    and this works too.
                    I also have the same problem, the local MM is not able to access a remote_compliments.conf file via URL in the local module\defaults\compliments folder, but I can access it from a browser. Seems to be the same problem!?
                      sdetweil @Snille
                      @Snille what is the view of the console in the MM dev window? should be an access error
                      • SnilleS Offline
                        @sdetweil Correct, it’s the cors error:
                        • karsten13K Offline
                          karsten13 @Snille
                          @Snille
                          if you can manage to insert http://localhost:8080/cors?url= so that the whole url is http://localhost:8080/cors?url=http://10.0.0.249: ... it should work
                          • SnilleS Offline
                            Snille Module Developer @karsten13
                            @karsten13 Almost… I can’t use “localhost” because then I cant access the “remote control” (and therefore can not open DevTools) from anywhere… So I have to set at least the “IP” of the mirror… But I still get the broken image…
                            But I get no errors in the console now… Hmm…
                              karsten13 @Snille
                              strange, may errors in the server logs?
                              • SnilleS Offline
                                @karsten13 in the (pm2 log) I get:
                                0|MagicMirror  | [11.04.2022 23:30.43.266] [LOG]
                                0|MagicMirror  | cors url: http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=5b341e663bd99335792031e6f0129db5502c3eddfc4e297f70bdbfbc284a528e
                                For every try. Now it no longer works in the browser… And if I curl it…
                                curl -sL http://10.0.0.112:8080/cors?url=http://10.0.0.249:8123/api/camera_proxy/camera.xiaomi_cloud_map_extractor?token=562f09c026b6a8a87de4dc0ed7bfe5273e23429c1fb152be3597c37cf1b6d2d0
                                I get nothing… :)
                                So, something is not working more now… :)
                                  karsten13 @Snille
                                  @Snille
                                  the cors url log entry is o.k., but no idea at the moment. I’m not sure if the ip (instead of localhost) works, will try to test this tomorrow (I have no homeassistant so this will be no real test) …
                                  • SnilleS Offline
                                    Hang on, I just reset everything “back”, reset the MMM-homeassistant-sensors
                                    to it’s “original” state but let the IP be set in the config… And now it works?
                                    What’s going on here?! :)
                                    All modules that are fetching pictures from other places are now working!?
                                    So, the config needs to have the actual IP of the mirror set now. I have been using 0.0.0.0 all the time… Also tried “localhost” and it did not work. But the actual IP works!
                                    Great!! Thank you all for helping out! :)
                                    • W Offline
                                      wmx
                                      Ok, I can reproduce this correction too! :-)
                                      After changing address: “0.0.0.0” to the real ip address: “192.168.x.y” and removing every additional config from this thread ALL images are back again!
                                      Thank you all for this simple but effictive solution!
                                        borrmi
                                        Yep! changing “0.0.0.0” to “192.168.x.x” solved the problem and pictures are shown! Thanks to everybody!
