    Compliments mod using custom.css
    6 Posts 3 Posters 1.8k Views 3 Watching
      mayfield
      Hello all
      My wife has a problem with the default compliments, specifically the word Sexy, so I’ve been modifying the default compliments.js located in /MagicMirror/modules/default/compliments however each time there is an update I have to do this again,
      How can I use the custom.css to overcome having to change compliments.js?
      mumblebajM S 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @mayfield
        @mayfield You can use your own custom file. See the MM Page for info.
        https://docs.magicmirror.builders/modules/compliments.html#screenshots
          sdetweil @mayfield
          @mayfield also, never change the source code mm ships.
          all configuration can be done in the config.js
             module:'compliments',
              position:
              config:{
                    compliments:{
                             morning :{
                             afternoon:{
                            ... etc
            mayfield
            OK well thats pretty simple lol and I take it that come next update that part I have just changed will stay the same?
              sdetweil @mayfield
              @mayfield config.js is YOURs, we don’t touch that file. that’s the whole point.
              as mentioned you can put the compliments text config itself in a file as well and use the remote file config option
                mayfield @sdetweil
                @sdetweil Appreciate the help Thanks
