    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
    • K
      katalopapi @sdetweil
      @sdetweil Thanks for the info:
      “u can setup the default calendar and not give it a position, but have it broadcast events”
      I assume you are saying I can display the family calendar using the default calendar module, is that correct? If so, do you have a pointer to start me in the right direction? I don’t see an ICAL associated with the google family calendar. I thought I needed mmm-googleCalendar for that.
      “I don’t know if mmm-googlecalendar does the broadcast”
      From the CX3 github readme:
      Compatible with randomBrainstormer/MMM-GoogleCalendar
      eventTransformer: (e) => {
      e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
      e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
      e.title = e.summary
      e.fulldayEvent = (e.start?.date) ? true : false
      return e
      Do I need to add the eventTransformer code to get it to add the googleCalendar events?
      Reply Quote 1
      • M
        MMRIZE @katalopapi
        @katalopapi
        There is some tip explanation on readme doc to use with google-calendar module.
        • K
          katalopapi
          @MMRIZE Do you have any example config you could share for using mmm-googleCalendar?
          M 1 Reply Last reply
          Reply Quote 1
            sdetweil @katalopapi
            @katalopapi googlecalendar doc says broadcastEvents:true
            • M
              MMRIZE @katalopapi
              @katalopapi
              We both posted at same time, so your previous post was right.
              K 1 Reply Last reply
              • K
                katalopapi @MMRIZE
                @MMRIZE I’m getting the following error:
                I assume I’m doing something wrong with the transformer since it seems to be an issue with startDate. Here’s my config:
                FYI
                I had to manually update MMM-GoogleCalendar.js to enable broadcastEvents. I couldn’t seem to enable via the config.js (perhaps I did something wrong).
                Any ideas regarding the error? TIA
                  @katalopapi all you had to do was add
                  broadcastEvents: true,
                  inside the module config: {}
                  section
                  as it is a module parameter and not a MagicMirror parameter (like position, disabled or classes)
                  • K
                    @sdetweil Thanks! I had it before the config. Works after moving it.
                    Reply Quote 1
                    • K
                      katalopapi
                      I’ve figured out what was causing the error. The US holiday events didn’t have the same fields as the google calendar so the transformer was messing those event us. I’ve fixed it with the following transformer:
                      Reply Quote 1
                      • A
                        agrusap
                        I’m on my phone sorry if this is messed up. I’m getting this error trying to use ext3 and cannot find an answer. I’m sure it’s something easy but…
                        Config is same as example given.
                        I don’t know how to post pictures so hope this helps
                        In dev window
                        Uncaught SyntaxError: unexpected token ? (Right side)
                        :8080/modules/MMM-calendarext3/MMM-calendarext3.js:54
                        S M 2 Replies Last reply
                          sdetweil @agrusap
                          @agrusap did u edit that file? never edit any module file or mm file.
                          ALL config goes in config.js
                          • M
                            MMRIZE @agrusap
                            @agrusap
                            Check your electron version(standalone) or browser version(server mode). This module is using a modern JS features, your JS engine might be somewhat outdated.
                            • ScrewyoudriverS
                              Screwyoudriver
                              I have a problem with position: “bottom_center”,
                              if I place it at position: “middle_center”, the calendar is the whole width of the screen.
                              But not at position: “bottom_center”,
                              Note: I moved it to bottom_bar and its fine
                                sdetweil @Screwyoudriver
                                @Screwyoudriver yes the regions are not all symmetrical…
                                see
                                https://forum.magicmirror.builders/topic/286/regions?_=1670987336099
                                ScrewyoudriverS 1 Reply Last reply
                                • ScrewyoudriverS
                                  Screwyoudriver @sdetweil
                                  it’s been a while since i did anything with the magicmirror.
                                  so I forgot this
                                  • T
                                    ThaliaFromPrussia
                                    I also have a problem. I have a series of appointments on Tuesday and Wednesday. If I change one appointment in length with the same starting time, it shifts one hour back. The source is correct, the displaying hour on the MM is incorrect. Does anybody else have this problem?
                                    MagicMirror
                                    Source in browser
                                    S 2 Replies Last reply
                                      sdetweil @ThaliaFromPrussia
                                      @ThaliaFromPrussia CalExt3 displays events read and processed by the default calendar module.
                                      this sounds like one of the utc/tinezone shift errors in one of the libraries we use.
                                      can u download the ics file and extract those two appointments before and after the change so I can examine the issue?
                                      to download the ics
                                      curl -sL cal_url > sonefile.txt
                                      then edit the somefile.txt
                                      events look like
                                      BEGIN VEVENT
                                      END VEVENT
                                      change anything that look personal
                                      don’t change the times or uuid
                                      if u don’t want to post the events here you can send it to me in a chat message or email.
                                      my email is my userid at gmail.
                                        @ThaliaFromPrussia thanks for the info… another library bug …
                                        the event was set in summer time
                                        the recurrence is in standard time
                                        the library returned the repeating as
                                        date :x , time :07:30
                                        I fix this one, adjusting for std time adjustments
                                        but on the recurrence
                                        date: y, time:08:30
                                        then the calendar module uses the tz, and it gets adjusted twice…
                                        once for berlin utc+1, and once for std time adjustment
                                        i haven’t figured out a way to fix this, the lib is not our code…
                                        T 1 Reply Last reply
                                        • T
                                          ThaliaFromPrussia @sdetweil
                                          @sdetweil Thank you and let me know if there is a way to fix it.
                                          • M
                                            megagprime
                                            hi everyone, another dumb question from yours truly, i’m looking to get this original calendar layout… which i cant get from default module calendar either for some reason
                                            how can i do this
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 34
                                            • 35
                                            • 11 / 35
