    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • K
      katalopapi @sdetweil
      @sdetweil Thanks! I had it before the config. Works after moving it.
      • K
        katalopapi
        I’ve figured out what was causing the error. The US holiday events didn’t have the same fields as the google calendar so the transformer was messing those event us. I’ve fixed it with the following transformer:
        • A
          agrusap
          I’m on my phone sorry if this is messed up. I’m getting this error trying to use ext3 and cannot find an answer. I’m sure it’s something easy but…
          Config is same as example given.
          I don’t know how to post pictures so hope this helps
          In dev window
          Uncaught SyntaxError: unexpected token ? (Right side)
          :8080/modules/MMM-calendarext3/MMM-calendarext3.js:54
          S M 2 Replies Last reply
            sdetweil @agrusap
            @agrusap did u edit that file? never edit any module file or mm file.
            ALL config goes in config.js
              MMRIZE @agrusap
              @agrusap
              Check your electron version(standalone) or browser version(server mode). This module is using a modern JS features, your JS engine might be somewhat outdated.
              • ScrewyoudriverS
                Screwyoudriver
                I have a problem with position: “bottom_center”,
                if I place it at position: “middle_center”, the calendar is the whole width of the screen.
                But not at position: “bottom_center”,
                Note: I moved it to bottom_bar and its fine
                  sdetweil @Screwyoudriver
                  @Screwyoudriver yes the regions are not all symmetrical…
                  see
                  https://forum.magicmirror.builders/topic/286/regions?_=1670987336099
                  ScrewyoudriverS 1 Reply Last reply
                  • ScrewyoudriverS
                    Screwyoudriver @sdetweil
                    it’s been a while since i did anything with the magicmirror.
                    so I forgot this
                    • T
                      ThaliaFromPrussia
                      I also have a problem. I have a series of appointments on Tuesday and Wednesday. If I change one appointment in length with the same starting time, it shifts one hour back. The source is correct, the displaying hour on the MM is incorrect. Does anybody else have this problem?
                      MagicMirror
                      Source in browser
                      S 2 Replies Last reply
                        sdetweil @ThaliaFromPrussia
                        @ThaliaFromPrussia CalExt3 displays events read and processed by the default calendar module.
                        this sounds like one of the utc/tinezone shift errors in one of the libraries we use.
                        can u download the ics file and extract those two appointments before and after the change so I can examine the issue?
                        to download the ics
                        curl -sL cal_url > sonefile.txt
                        then edit the somefile.txt
                        events look like
                        BEGIN VEVENT
                        END VEVENT
                        change anything that look personal
                        don’t change the times or uuid
                        if u don’t want to post the events here you can send it to me in a chat message or email.
                        my email is my userid at gmail.
                          @ThaliaFromPrussia thanks for the info… another library bug …
                          the event was set in summer time
                          the recurrence is in standard time
                          the library returned the repeating as
                          date :x , time :07:30
                          I fix this one, adjusting for std time adjustments
                          but on the recurrence
                          date: y, time:08:30
                          then the calendar module uses the tz, and it gets adjusted twice…
                          once for berlin utc+1, and once for std time adjustment
                          i haven’t figured out a way to fix this, the lib is not our code…
                          T 1 Reply Last reply
                          • T
                            ThaliaFromPrussia @sdetweil
                            @sdetweil Thank you and let me know if there is a way to fix it.
                              megagprime
                              hi everyone, another dumb question from yours truly, i’m looking to get this original calendar layout… which i cant get from default module calendar either for some reason
                              how can i do this
                                sdetweil @megagprime
                                @megagprime this calendar ?
                                M 1 Reply Last reply
                                  megagprime @sdetweil
                                  @sdetweil yes, any of the ext or even the original calendar module, whats the view for the simple list?
                                    @megagprime that is the default calendar view.
                                    you add your ical url to the module config, replacing the US holidays url…
                                    note the ical url, not the embed url.
                                    really simple. if u use Google calendar
                                    open calendar.google.com on a PC
                                    in left nav, hover mouse over your calendar name,
                                    3 dots appear, click, select properties
                                    new stuff appears right,
                                    scroll down to sharing, ical
                                    select the public or secret url click copy
                                    that’s the url to use in mm
                                    • F
                                      fedale
                                      Does anyone have a working config for google calendar. The old code i had in EXT2 isnt working with the new EXT3.
                                      In the new EXT3 one i cannot get any feedback from google.
                                        sdetweil @fedale
                                        @fedale ext3 does not read the calendar itself, like old ext2 did.
                                        .ext3 depends on the default calendar to read the ics data and broadcast the events
                                        so add your url to the default calendar module, and remove it’s position so it doesn’t show.
                                        then ext3 will receive the broadcast message
                                        F 1 Reply Last reply
                                        • F
                                          fedale @sdetweil
                                          @sdetweil Thanks, that worked like a charm.
                                          Have some other questions.
                                          1. How to remove the CW wording, infront of the weeks number?
                                          2. The eventTransformer does not color not-fullday items. Is there a quick work around for that?
                                            So if i have only an hour in my calendar will still show color.
                                          eventTransformer: (ev) => {
                                          if (ev.title.search(‘garbage’) > -1) ev.color = ‘green’
                                          return ev
                                          1. Also i add picture to the eventTransformer? I had a recyle one for this garbage earlier.
                                          S F B 3 Replies Last reply
                                            sdetweil @fedale
                                            @fedale not sure on cw,
                                            you could check if it’s full day event. not sure. not my module
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 34
                                            • 35
                                            • 11 / 35
