    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      sdetweil @Screwyoudriver
      @Screwyoudriver yes the regions are not all symmetrical…
      see
      https://forum.magicmirror.builders/topic/286/regions?_=1670987336099
      ScrewyoudriverS 1 Reply Last reply Reply Quote 0
      • ScrewyoudriverS Offline
        Screwyoudriver @sdetweil
        it’s been a while since i did anything with the magicmirror.
        so I forgot this
        • T Offline
          ThaliaFromPrussia
          I also have a problem. I have a series of appointments on Tuesday and Wednesday. If I change one appointment in length with the same starting time, it shifts one hour back. The source is correct, the displaying hour on the MM is incorrect. Does anybody else have this problem?
          MagicMirror
          Source in browser
            sdetweil @ThaliaFromPrussia
            @ThaliaFromPrussia CalExt3 displays events read and processed by the default calendar module.
            this sounds like one of the utc/tinezone shift errors in one of the libraries we use.
            can u download the ics file and extract those two appointments before and after the change so I can examine the issue?
            to download the ics
            curl -sL cal_url > sonefile.txt
            then edit the somefile.txt
            events look like
            BEGIN VEVENT
            END VEVENT
            change anything that look personal
            don’t change the times or uuid
            if u don’t want to post the events here you can send it to me in a chat message or email.
            my email is my userid at gmail.
              @ThaliaFromPrussia thanks for the info… another library bug …
              the event was set in summer time
              the recurrence is in standard time
              the library returned the repeating as
              date :x , time :07:30
              I fix this one, adjusting for std time adjustments
              but on the recurrence
              date: y, time:08:30
              then the calendar module uses the tz, and it gets adjusted twice…
              once for berlin utc+1, and once for std time adjustment
              i haven’t figured out a way to fix this, the lib is not our code…
              • T Offline
                ThaliaFromPrussia @sdetweil
                @sdetweil Thank you and let me know if there is a way to fix it.
                  megagprime
                  hi everyone, another dumb question from yours truly, i’m looking to get this original calendar layout… which i cant get from default module calendar either for some reason
                  how can i do this
                    sdetweil @megagprime
                    @megagprime this calendar ?
                      megagprime @sdetweil
                      @sdetweil yes, any of the ext or even the original calendar module, whats the view for the simple list?
                        @megagprime that is the default calendar view.
                        you add your ical url to the module config, replacing the US holidays url…
                        note the ical url, not the embed url.
                        really simple. if u use Google calendar
                        open calendar.google.com on a PC
                        in left nav, hover mouse over your calendar name,
                        3 dots appear, click, select properties
                        new stuff appears right,
                        scroll down to sharing, ical
                        select the public or secret url click copy
                        that’s the url to use in mm
                        • F Offline
                          fedale
                          Does anyone have a working config for google calendar. The old code i had in EXT2 isnt working with the new EXT3.
                          In the new EXT3 one i cannot get any feedback from google.
                            sdetweil @fedale
                            @fedale ext3 does not read the calendar itself, like old ext2 did.
                            .ext3 depends on the default calendar to read the ics data and broadcast the events
                            so add your url to the default calendar module, and remove it’s position so it doesn’t show.
                            then ext3 will receive the broadcast message
                            • F Offline
                              fedale @sdetweil
                              @sdetweil Thanks, that worked like a charm.
                              Have some other questions.
                              1. How to remove the CW wording, infront of the weeks number?
                              2. The eventTransformer does not color not-fullday items. Is there a quick work around for that?
                                So if i have only an hour in my calendar will still show color.
                              eventTransformer: (ev) => {
                              if (ev.title.search(‘garbage’) > -1) ev.color = ‘green’
                              return ev
                              1. Also i add picture to the eventTransformer? I had a recyle one for this garbage earlier.
                              S F B 3 Replies Last reply Reply Quote 0
                                sdetweil @fedale
                                @fedale not sure on cw,
                                you could check if it’s full day event. not sure. not my module
                                • F Offline
                                  fedale @fedale
                                  @MMRIZE Any surgestions?
                                  return ev
                                    bicolorbore586 @fedale
                                    @fedale
                                    I have the below in my custom.css
                                    /* MMM-CalendarExt3 */
                                    .CX3 .cw {
                                    display:none;
                                    • F Offline
                                      fedale @bicolorbore586
                                      • F Offline
                                        fedale @fedale
                                        I learnt something new, never thought to look into the module folder css file.
                                        Always though only the main.css and custom.css was the only ones to change.
                                        Found the wordning now in MMM-CalendarExt3.css file within the module.
                                        Removing the CW, the way i wanted. Just wanted to share.
                                        MMM-CalendarExt3.css file and remove the CW to only get the week number:
                                        .CX3 .cw::before {
                                        content: 'CW ’
                                        S B K 3 Replies Last reply Reply Quote 0
                                          sdetweil @fedale
                                          @fedale u can override that in the custom.css
                                          don’t change the modules files, it will break upgraded and fixes
                                            @fedale yes, as Sam says, don’t modify the module css, all css work should be done in the custom.css
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
