    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      sdetweil @ThaliaFromPrussia
      @ThaliaFromPrussia thanks for the info… another library bug …
      the event was set in summer time
      the recurrence is in standard time
      the library returned the repeating as
      date :x , time :07:30
      I fix this one, adjusting for std time adjustments
      but on the recurrence
      date: y, time:08:30
      then the calendar module uses the tz, and it gets adjusted twice…
      once for berlin utc+1, and once for std time adjustment
      i haven’t figured out a way to fix this, the lib is not our code…
      • T Offline
        ThaliaFromPrussia @sdetweil
        @sdetweil Thank you and let me know if there is a way to fix it.
          megagprime
          hi everyone, another dumb question from yours truly, i’m looking to get this original calendar layout… which i cant get from default module calendar either for some reason
          how can i do this
            sdetweil @megagprime
            @megagprime this calendar ?
              megagprime @sdetweil
              @sdetweil yes, any of the ext or even the original calendar module, whats the view for the simple list?
                @megagprime that is the default calendar view.
                you add your ical url to the module config, replacing the US holidays url…
                note the ical url, not the embed url.
                really simple. if u use Google calendar
                open calendar.google.com on a PC
                in left nav, hover mouse over your calendar name,
                3 dots appear, click, select properties
                new stuff appears right,
                scroll down to sharing, ical
                select the public or secret url click copy
                that’s the url to use in mm
                • F Offline
                  fedale
                  Does anyone have a working config for google calendar. The old code i had in EXT2 isnt working with the new EXT3.
                  In the new EXT3 one i cannot get any feedback from google.
                    sdetweil @fedale
                    @fedale ext3 does not read the calendar itself, like old ext2 did.
                    .ext3 depends on the default calendar to read the ics data and broadcast the events
                    so add your url to the default calendar module, and remove it’s position so it doesn’t show.
                    then ext3 will receive the broadcast message
                    • F Offline
                      fedale @sdetweil
                      @sdetweil Thanks, that worked like a charm.
                      Have some other questions.
                      1. How to remove the CW wording, infront of the weeks number?
                      2. The eventTransformer does not color not-fullday items. Is there a quick work around for that?
                        So if i have only an hour in my calendar will still show color.
                      eventTransformer: (ev) => {
                      if (ev.title.search(‘garbage’) > -1) ev.color = ‘green’
                      return ev
                      1. Also i add picture to the eventTransformer? I had a recyle one for this garbage earlier.
                      S F B 3 Replies Last reply Reply Quote 0
                        sdetweil @fedale
                        @fedale not sure on cw,
                        you could check if it’s full day event. not sure. not my module
                        • F Offline
                          fedale @fedale
                          @MMRIZE Any surgestions?
                          return ev
                            bicolorbore586 @fedale
                            @fedale
                            I have the below in my custom.css
                            /* MMM-CalendarExt3 */
                            .CX3 .cw {
                            display:none;
                            • F Offline
                              fedale @bicolorbore586
                              • F Offline
                                fedale @fedale
                                I learnt something new, never thought to look into the module folder css file.
                                Always though only the main.css and custom.css was the only ones to change.
                                Found the wordning now in MMM-CalendarExt3.css file within the module.
                                Removing the CW, the way i wanted. Just wanted to share.
                                MMM-CalendarExt3.css file and remove the CW to only get the week number:
                                .CX3 .cw::before {
                                content: 'CW ’
                                S B K 3 Replies Last reply Reply Quote 0
                                  sdetweil @fedale
                                  @fedale u can override that in the custom.css
                                  don’t change the modules files, it will break upgraded and fixes
                                    @fedale yes, as Sam says, don’t modify the module css, all css work should be done in the custom.css
                                    • F Offline
                                      @bicolorbore586 Thanks guys.
                                      • F Offline
                                        fedale
                                        Could i have icons on different words in calendar?
                                        I only have one calendar, but previously cx2 could get with differnt pictures like this example.
                                         if (event.title.search("Work") > -1) {
                                        	event.icon = "ic:outline-work-outline";
                                        	event.className = "work"
                                        else if(event.title.search(“Trash”) > -1) {
                                        event.icon = “mdi:recycle”;
                                        event.className = “Trash”
                                          sdetweil @fedale
                                          @fedale I think it works the same
                                            MMRIZE @fedale
                                            @fedale
                                            CX3 has not support Iconify icons yet, only FontAwesome. It would be applied in near future updates.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
