    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      bicolorbore586 @fedale
      @fedale
      I have the below in my custom.css
      /* MMM-CalendarExt3 */
      .CX3 .cw {
      display:none;
      • F
        fedale @bicolorbore586
        • F
          fedale @fedale
          I learnt something new, never thought to look into the module folder css file.
          Always though only the main.css and custom.css was the only ones to change.
          Found the wordning now in MMM-CalendarExt3.css file within the module.
          Removing the CW, the way i wanted. Just wanted to share.
          MMM-CalendarExt3.css file and remove the CW to only get the week number:
          .CX3 .cw::before {
          content: 'CW ’
          S B K 3 Replies Last reply Reply Quote 0
            sdetweil @fedale
            @fedale u can override that in the custom.css
            don’t change the modules files, it will break upgraded and fixes
              @fedale yes, as Sam says, don’t modify the module css, all css work should be done in the custom.css
              • F
                @bicolorbore586 Thanks guys.
                • F
                  fedale
                  Could i have icons on different words in calendar?
                  I only have one calendar, but previously cx2 could get with differnt pictures like this example.
                   if (event.title.search("Work") > -1) {
                  	event.icon = "ic:outline-work-outline";
                  	event.className = "work"
                  else if(event.title.search(“Trash”) > -1) {
                  event.icon = “mdi:recycle”;
                  event.className = “Trash”
                    sdetweil @fedale
                    @fedale I think it works the same
                      MMRIZE @fedale
                      @fedale
                      CX3 has not support Iconify icons yet, only FontAwesome. It would be applied in near future updates.
                        bicolorbore586
                        Is there a way of getting icons to sit in specific top bars (with the date number) of cells/days?
                        I use MMM-CalendarExt3 to show my upcoming month, the default calendar to show the next couple of days events and MMM-Birthdays to show upcoming birthdays.
                        What I would like to do is have a birthday cake icon sat in the date field, so I can see that that date is a birthday, without any written information in the cell, i.e. the white line wouldn’t be there in the image below.
                        S M 3 Replies Last reply Reply Quote 0
                          sdetweil @bicolorbore586
                          @bicolorbore586 no way without changing the module code. can’t move it w css
                            MMRIZE @bicolorbore586
                            @bicolorbore586
                            Sorry, It can’t be done at this moment. In some day, I have a plan to update. I’ll consider your needs at that time.
                              redink
                              Can anyone help me make one last tweak? I would like to get rid of the icon next to the event name and display the event time in just a 24 hour format (23:30 instead of 11:30 PM). Here’s my current config
                                module: "MMM-CalendarExt3",
                                position: "bottom_bar",
                                title: "",
                                  mode: "week",
                                  instanceId: "basicCalendar",
                                  locale: 'en-EN',
                                  weekIndex: 0,
                                  weeksInView: 4,
                                  maxEventLines: 5,
                                  firstDayOfWeek: 0,
                                  fontSize: "22px",
                                  eventTimeOptions: {
                                    hour: "2-digit",
                                    minute : "2-digit"
                                  useSymbol: false,
                                  calendarSet: ['School', 'Family'],
                                MMRIZE @redink
                                @redink
                                1. Add this into your custom.css
                                .CX3 .event.singleday:not(.useSymbol)::before,
                                .CX3 .event.singleday.useSymbol .symbol.noSymbol::before {
                                  display:none;
                                1. Use this eventTimeOptions;
                                eventTimeOptions: {
                                	hour12: false,
                                	hour: "2-digit",
                                	minute : "2-digit"
                                  redink @MMRIZE
                                  @MMRIZE Perfect! Thank you so much.
                                    MMRIZE
                                    1.3.0 (2023-04-17)
                                    • CHANGED: Shared library to fix many issues.
                                    • FIXED: some typo.
                                    • FIXED: flickering for many reasons (logic error to treat notifications)
                                    • ADDED: CX3_RESET_DATE notification (to reset instantly from glancing)
                                    • ADDED: MMM-TelegramBot user implementation example
                                    • ADDED: preProcessor for better handling of raw-data priorly
                                    • ADDED: manipulateDateCell to manipulate date cell DOM after drawing
                                    • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                                      @bicolorbore586
                                      Since 1.3.0, with manipulateDateCell callback function in configuration, you can handle date cell itself. So you can achieve what you want.
                                      Here is a simple example; (more tweek might be needed to match with your wants wholely)
                                      manipulateDateCell: (cell, events) => {
                                      	if (Array.isArray(events) && events.some(e => e.calendarName === 'Holidays')) {
                                      		let dateIcon = document.createElement('span')
                                      		dateIcon.classList.add('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                                      		dateIcon.style.color = 'red'
                                      		dateIcon.style.fontSize = '0.9em'
                                      		let header = cell.querySelector('.cellHeader')
                                      		let celldate = header.querySelector('.cellDate')
                                      		header.insertBefore(dateIcon, celldate)
                                      Anyway, it could be possible.
                                      B 2 Replies Last reply Reply Quote 1
                                        bicolorbore586 @MMRIZE
                                        @MMRIZE
                                        Hi MMRIZE, this looks amazing. I will be sure to update and give it a whirl!
                                        • Z
                                          zelmo
                                          Is there anyway to make it show the end time in the montly calendar?
                                          Like:
                                          7:00 - 8:15 Morning Rutine
                                          instead of
                                          7:00 Morning Rutine
                                          That would help out lots when looking at it to make sure you don’t double book yourself if you don’t remember how long the specific event you are going to will last.
                                            MMRIZE @zelmo
                                            @zelmo
                                            It is intentionally designed so. Not enough width to display endTime together. Use MMM-CalendarExt3Agenda together to see details.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
