    MMM-CalendarExt3
    689 Posts 82 Posters 2.8m Views 86 Watching
    • F Offline
      fedale @sdetweil
      @sdetweil Thanks, that worked like a charm.
      Have some other questions.
      1. How to remove the CW wording, infront of the weeks number?
      2. The eventTransformer does not color not-fullday items. Is there a quick work around for that?
        So if i have only an hour in my calendar will still show color.
      eventTransformer: (ev) => {
      if (ev.title.search(‘garbage’) > -1) ev.color = ‘green’
      return ev
      1. Also i add picture to the eventTransformer? I had a recyle one for this garbage earlier.
      S F B 3 Replies Last reply Reply Quote 0
        sdetweil @fedale
        @fedale not sure on cw,
        you could check if it’s full day event. not sure. not my module
        • F Offline
          fedale @fedale
          @MMRIZE Any surgestions?
          return ev
            bicolorbore586 @fedale
            @fedale
            I have the below in my custom.css
            /* MMM-CalendarExt3 */
            .CX3 .cw {
            display:none;
            • F Offline
              fedale @bicolorbore586
              • F Offline
                fedale @fedale
                I learnt something new, never thought to look into the module folder css file.
                Always though only the main.css and custom.css was the only ones to change.
                Found the wordning now in MMM-CalendarExt3.css file within the module.
                Removing the CW, the way i wanted. Just wanted to share.
                MMM-CalendarExt3.css file and remove the CW to only get the week number:
                .CX3 .cw::before {
                content: 'CW ’
                S B K 3 Replies Last reply Reply Quote 0
                  sdetweil @fedale
                  @fedale u can override that in the custom.css
                  don’t change the modules files, it will break upgraded and fixes
                    @fedale yes, as Sam says, don’t modify the module css, all css work should be done in the custom.css
                    • F Offline
                      @bicolorbore586 Thanks guys.
                      • F Offline
                        fedale
                        Could i have icons on different words in calendar?
                        I only have one calendar, but previously cx2 could get with differnt pictures like this example.
                         if (event.title.search("Work") > -1) {
                        	event.icon = "ic:outline-work-outline";
                        	event.className = "work"
                        else if(event.title.search(“Trash”) > -1) {
                        event.icon = “mdi:recycle”;
                        event.className = “Trash”
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 68
                        • 69
                        • 23 / 69
