    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
    • F
      fedale @fedale
      I learnt something new, never thought to look into the module folder css file.
      Always though only the main.css and custom.css was the only ones to change.
      Found the wordning now in MMM-CalendarExt3.css file within the module.
      Removing the CW, the way i wanted. Just wanted to share.
      MMM-CalendarExt3.css file and remove the CW to only get the week number:
      .CX3 .cw::before {
      content: 'CW ’
      S B K 3 Replies Last reply
        sdetweil @fedale
        @fedale u can override that in the custom.css
        don’t change the modules files, it will break upgraded and fixes
          bicolorbore586 @fedale
          @fedale yes, as Sam says, don’t modify the module css, all css work should be done in the custom.css
          F 1 Reply Last reply
          • F
            fedale @bicolorbore586
            @bicolorbore586 Thanks guys.
            • F
              fedale
              Could i have icons on different words in calendar?
              I only have one calendar, but previously cx2 could get with differnt pictures like this example.
               if (event.title.search("Work") > -1) {
              	event.icon = "ic:outline-work-outline";
              	event.className = "work"
              else if(event.title.search(“Trash”) > -1) {
              event.icon = “mdi:recycle”;
              event.className = “Trash”
              S M 2 Replies Last reply
                sdetweil @fedale
                @fedale I think it works the same
                  MMRIZE @fedale
                  @fedale
                  CX3 has not support Iconify icons yet, only FontAwesome. It would be applied in near future updates.
                    bicolorbore586
                    Is there a way of getting icons to sit in specific top bars (with the date number) of cells/days?
                    I use MMM-CalendarExt3 to show my upcoming month, the default calendar to show the next couple of days events and MMM-Birthdays to show upcoming birthdays.
                    What I would like to do is have a birthday cake icon sat in the date field, so I can see that that date is a birthday, without any written information in the cell, i.e. the white line wouldn’t be there in the image below.
                    S M 3 Replies Last reply
                      sdetweil @bicolorbore586
                      @bicolorbore586 no way without changing the module code. can’t move it w css
                        MMRIZE @bicolorbore586
                        @bicolorbore586
                        Sorry, It can’t be done at this moment. In some day, I have a plan to update. I’ll consider your needs at that time.
                          redink
                          Can anyone help me make one last tweak? I would like to get rid of the icon next to the event name and display the event time in just a 24 hour format (23:30 instead of 11:30 PM). Here’s my current config
                            module: "MMM-CalendarExt3",
                            position: "bottom_bar",
                            title: "",
                              mode: "week",
                              instanceId: "basicCalendar",
                              locale: 'en-EN',
                              weekIndex: 0,
                              weeksInView: 4,
                              maxEventLines: 5,
                              firstDayOfWeek: 0,
                              fontSize: "22px",
                              eventTimeOptions: {
                                hour: "2-digit",
                                minute : "2-digit"
                              useSymbol: false,
                              calendarSet: ['School', 'Family'],
                          M 1 Reply Last reply
                            MMRIZE @redink
                            @redink
                            1. Add this into your custom.css
                            .CX3 .event.singleday:not(.useSymbol)::before,
                            .CX3 .event.singleday.useSymbol .symbol.noSymbol::before {
                              display:none;
                            1. Use this eventTimeOptions;
                            eventTimeOptions: {
                            	hour12: false,
                            	hour: "2-digit",
                            	minute : "2-digit"
                            R 1 Reply Last reply
                              redink @MMRIZE
                              @MMRIZE Perfect! Thank you so much.
                                MMRIZE
                                1.3.0 (2023-04-17)
                                • CHANGED: Shared library to fix many issues.
                                • FIXED: some typo.
                                • FIXED: flickering for many reasons (logic error to treat notifications)
                                • ADDED: CX3_RESET_DATE notification (to reset instantly from glancing)
                                • ADDED: MMM-TelegramBot user implementation example
                                • ADDED: preProcessor for better handling of raw-data priorly
                                • ADDED: manipulateDateCell to manipulate date cell DOM after drawing
                                • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                                  @bicolorbore586
                                  Since 1.3.0, with manipulateDateCell callback function in configuration, you can handle date cell itself. So you can achieve what you want.
                                  Here is a simple example; (more tweek might be needed to match with your wants wholely)
                                  manipulateDateCell: (cell, events) => {
                                  	if (Array.isArray(events) && events.some(e => e.calendarName === 'Holidays')) {
                                  		let dateIcon = document.createElement('span')
                                  		dateIcon.classList.add('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                                  		dateIcon.style.color = 'red'
                                  		dateIcon.style.fontSize = '0.9em'
                                  		let header = cell.querySelector('.cellHeader')
                                  		let celldate = header.querySelector('.cellDate')
                                  		header.insertBefore(dateIcon, celldate)
                                  Anyway, it could be possible.
                                  B 2 Replies Last reply
                                    bicolorbore586 @MMRIZE
                                    @MMRIZE
                                    Hi MMRIZE, this looks amazing. I will be sure to update and give it a whirl!
                                    • Z
                                      zelmo
                                      Is there anyway to make it show the end time in the montly calendar?
                                      Like:
                                      7:00 - 8:15 Morning Rutine
                                      instead of
                                      7:00 Morning Rutine
                                      That would help out lots when looking at it to make sure you don’t double book yourself if you don’t remember how long the specific event you are going to will last.
                                        MMRIZE @zelmo
                                        @zelmo
                                        It is intentionally designed so. Not enough width to display endTime together. Use MMM-CalendarExt3Agenda together to see details.
                                          MMRIZE @zelmo
                                          1.3.1 (2023-05-02)
                                          • CHANGED: Refactoring some codes, the structure of the events, CSS.
                                          • ADDED: displayEndTime: true => Show end time of the event. (hidden by default) (Requested from @zelmo)
                                          • ADDED: displayWeatherTemp: true => Show max/min temperature of the forecasted days.
                                            CX3_1 3 1
                                            MMRIZE @zelmo
                                            @zelmo updated for you.
                                            Z 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
