    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      sdetweil @fedale
      @fedale I think it works the same
        MMRIZE @fedale
        @fedale
        CX3 has not support Iconify icons yet, only FontAwesome. It would be applied in near future updates.
          bicolorbore586
          Is there a way of getting icons to sit in specific top bars (with the date number) of cells/days?
          I use MMM-CalendarExt3 to show my upcoming month, the default calendar to show the next couple of days events and MMM-Birthdays to show upcoming birthdays.
          What I would like to do is have a birthday cake icon sat in the date field, so I can see that that date is a birthday, without any written information in the cell, i.e. the white line wouldn’t be there in the image below.
          S M 3 Replies Last reply
            sdetweil @bicolorbore586
            @bicolorbore586 no way without changing the module code. can’t move it w css
              MMRIZE @bicolorbore586
              @bicolorbore586
              Sorry, It can’t be done at this moment. In some day, I have a plan to update. I’ll consider your needs at that time.
                redink
                Can anyone help me make one last tweak? I would like to get rid of the icon next to the event name and display the event time in just a 24 hour format (23:30 instead of 11:30 PM). Here’s my current config
                  module: "MMM-CalendarExt3",
                  position: "bottom_bar",
                  title: "",
                    mode: "week",
                    instanceId: "basicCalendar",
                    locale: 'en-EN',
                    weekIndex: 0,
                    weeksInView: 4,
                    maxEventLines: 5,
                    firstDayOfWeek: 0,
                    fontSize: "22px",
                    eventTimeOptions: {
                      hour: "2-digit",
                      minute : "2-digit"
                    useSymbol: false,
                    calendarSet: ['School', 'Family'],
                M 1 Reply Last reply
                  MMRIZE @redink
                  @redink
                  1. Add this into your custom.css
                  .CX3 .event.singleday:not(.useSymbol)::before,
                  .CX3 .event.singleday.useSymbol .symbol.noSymbol::before {
                    display:none;
                  1. Use this eventTimeOptions;
                  eventTimeOptions: {
                  	hour12: false,
                  	hour: "2-digit",
                  	minute : "2-digit"
                  R 1 Reply Last reply
                    redink @MMRIZE
                    @MMRIZE Perfect! Thank you so much.
                      MMRIZE
                      1.3.0 (2023-04-17)
                      • CHANGED: Shared library to fix many issues.
                      • FIXED: some typo.
                      • FIXED: flickering for many reasons (logic error to treat notifications)
                      • ADDED: CX3_RESET_DATE notification (to reset instantly from glancing)
                      • ADDED: MMM-TelegramBot user implementation example
                      • ADDED: preProcessor for better handling of raw-data priorly
                      • ADDED: manipulateDateCell to manipulate date cell DOM after drawing
                      • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                        @bicolorbore586
                        Since 1.3.0, with manipulateDateCell callback function in configuration, you can handle date cell itself. So you can achieve what you want.
                        Here is a simple example; (more tweek might be needed to match with your wants wholely)
                        manipulateDateCell: (cell, events) => {
                        	if (Array.isArray(events) && events.some(e => e.calendarName === 'Holidays')) {
                        		let dateIcon = document.createElement('span')
                        		dateIcon.classList.add('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                        		dateIcon.style.color = 'red'
                        		dateIcon.style.fontSize = '0.9em'
                        		let header = cell.querySelector('.cellHeader')
                        		let celldate = header.querySelector('.cellDate')
                        		header.insertBefore(dateIcon, celldate)
                        Anyway, it could be possible.
                        B 2 Replies Last reply
                          bicolorbore586 @MMRIZE
                          @MMRIZE
                          Hi MMRIZE, this looks amazing. I will be sure to update and give it a whirl!
                          • Z
                            zelmo
                            Is there anyway to make it show the end time in the montly calendar?
                            Like:
                            7:00 - 8:15 Morning Rutine
                            instead of
                            7:00 Morning Rutine
                            That would help out lots when looking at it to make sure you don’t double book yourself if you don’t remember how long the specific event you are going to will last.
                              MMRIZE @zelmo
                              @zelmo
                              It is intentionally designed so. Not enough width to display endTime together. Use MMM-CalendarExt3Agenda together to see details.
                                MMRIZE @zelmo
                                1.3.1 (2023-05-02)
                                • CHANGED: Refactoring some codes, the structure of the events, CSS.
                                • ADDED: displayEndTime: true => Show end time of the event. (hidden by default) (Requested from @zelmo)
                                • ADDED: displayWeatherTemp: true => Show max/min temperature of the forecasted days.
                                  CX3_1 3 1
                                  MMRIZE @zelmo
                                  @zelmo updated for you.
                                  Z 1 Reply Last reply
                                  • Z
                                    zelmo @MMRIZE
                                    @MMRIZE Thanks a lot! Was about to suggest it just in case someone would run it horizontal. Then it might be useful and enough space. I’ll test out at least. Thanks again.
                                      Studio472
                                      I added an mlb team calendar. The little baseball symbol shows up on my google calendar on the web browser. In this module, the icon isn’t coming through. Is there a module or font-pack I need to install on my raspbizzle?
                                        MMRIZE @Studio472
                                        @Studio472
                                        Maybe emoji font should be installed to use/display emojis.
                                        https://raspberrypi.stackexchange.com/questions/104181/colored-emojis-in-chromium
                                        • W
                                          whimsicality
                                          Hi, thanks for the work on this module. I am struggling to get it to load. I finally ran the npm dev through terminal and it is coming up with a number of errors… “failed to retrieve device information”, “failed to open kms_swrast”, “failed to open swrast”, “gpu process exited unexpectedly” exit_code=11", “failed to send GpuControl.createcommandbuffer” and then it looks like electron exited with signal “SIGINT”.
                                          Is this something I need to troubleshoot with the module itself or does this mean I need to fix something elsewhere? thanks!
                                            sdetweil @whimsicality
                                            @whimsicality
                                            for the mesa errors this is an electron/graphics engine problem. but you can turn off gpu use.
                                            in the script that starts mm, ~/MagicMirror/installers/mm.sh if you used my install script, add
                                            export ELECTRON_DISABLE_GPU=1
                                            above the line that does npm start
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
