    MMM-CalendarExt3
    687 Posts 82 Posters 2.8m Views 86 Watching
      sdetweil @luisestrada
      @luisestrada each sends out its own list of entries. maybe calext3 is replacing a with b with c
      luisestradaL 1 Reply Last reply Reply Quote 0
      • luisestradaL Offline
        luisestrada @sdetweil
        @sdetweil said in MMM-CalendarExt3:
        That’s exactly what i thought, so thats why I created 3 different modules by copying the entire module in a separate folder and renaming it, similar to this: https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
        but still, if I have 3 modules called, calendar, calendar1 and calendar2, it does it
        M S 3 Replies Last reply Reply Quote 0
          MMRIZE @luisestrada
          @luisestrada
          Well, I was worried about just that case when I developed this module - multiple calendar instances. I thought Nobody would use the calendar module like that. So I haven’t considered supporting that case. But I was wrong.
          The current behaviour of this module is replacing whole events when the notification arrives, not combining each. So you cannot get proper whole events from multi-emitter of notifications.
          I’ll modify the module in a few days to stack each event not replace it. Wait for a little.
            MMRIZE @luisestrada
            @luisestrada
            By the way, your configuration is not quite effective. Some options are located in the wrong place, some are invalid.
            • All module-specific user configuration should be placed in config: { ... }. Your waitFecth or eventTimeOptions and something more would not be applied.
            • there is no fetchInterval or rotateInterval option in CX3.
            • broadcastPastEvents is not for CX3 module but for calendar module.
            • refreshInterval: 1000 * 60 * 1 means redraw calendar every 1 minute. Is it really needed?
              @luisestrada the info inside(event broadcast) is still the same
              and u didn’t need to do the rename. it supports multiple instances
                sdetweil @MMRIZE
                @MMRIZE u can see in config if multiple instances and maybe the ‘from’ on notification
                  luisestrada @MMRIZE
                  @MMRIZE said in MMM-CalendarExt3:
                  @luisestrada
                  Thank you, I will show you my code so you all can understand the mess I did :beaming_face_with_smiling_eyes:
                  @luisestrada
                  It was supposed to be ten minutes but because I was trying and adding and testing, I forgot to change it back
                    All calendar were working under the same name, however i thought it was the cause of the blank CX3 so that’s why i tried to create one version for each module as a last resort
                      luisestrada
                      My code with the changes based on your feedback (and it seems to be working for now) Thank you!
                      //Calendar hidden Module
                                  //position: "top_left",
                                  header: "Eventos",
                                      broadcastPastEvents: true, // <= IMPORTANT to see past events
                                      instanceId: "WeeklyCalendar",
                                              url: "URL1",
                                              name: "Cal1", // <= RECOMMENDED to assign name
                                              color: "#0760d1", // <= RECOMMENDED to assign color
                                              symbol: false
                                              url: "URL2",
                                              name: "Cal2", // <= RECOMMENDED to assign name
                                              color: "#2a4d56", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                              symbol: "birthday-cake"
                                              url: "URL3",
                                              name: "Cal3", // <= RECOMMENDED to assign name
                                              color: "#333", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                              symbol: "bank"
                                              url: "URL4",
                                              name: "Cal4", // <= RECOMMENDED to assign name
                                              color: "#3f0101", // <= RECOMMENDED to assign color
                                              symbol: "flag"
                                              url: "URL5",
                                              name: "Cal5, // <= RECOMMENDED to assign name
                                              color: "#765f02", //rgb(58%, 24%, 45%) // <= RECOMMENDED to assign color
                                              symbol: "flag"
                      // CX3 Module
                                  module: "MMM-CalendarExt3",
                                  position: "bottom_bar",
                                  title: "Calendario",
                                      mode: "week",
                                      locale: 'es-CO',
                                      maxEventLines: 3,
                                      firstDayOfWeek: 0,
                                      weekIndex: 0,
                                      weeksInView: 4,
                                      waitFetch: 1000 * 10, //	(ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                                      refreshInterval: 1000 * 60 * 10, //	(ms) refresh view by force if you need it.
                                      glanceTime: 1000 * 60 * 10,	// (ms) Return to original view when you move to other moment by notification.
                                      eventTimeOptions: {
                                          timeStyle: "short"
                                      //useSymbol: false,
                                      calendarSet: ['Cal1', 'Cal2', 'Cal3', 'Cal4', 'Cal5'],
                      Now these 3 calendars seem not to be conflicting with CX3
                      			module: "calendar2",
                      			header: "CAL2",
                                              url: "CAL2"
                      				maximumEntries: "2",
                                      wrapEvents: true
                      			header: "CAL3",
                                              url: "CAL3"
                      				maximumEntries: "3",
                                      wrapEvents: true
                      			header: "CAL",
                                              url: "CAL"
                      				maximumEntries: "5",
                                      wrapEvents: true
                      Sorry for the long message
                        luisestrada @luisestrada
                        @luisestrada said in MMM-CalendarExt3:
                        I talked too fast, I pressed submit and the issue came back :anxious_face_with_sweat:
                        • 6
                        • 68
                        • 69
                        • 4 / 69
