    Graph module
    26 Posts 9 Posters 21.8k Views 9 Watching
    • F Offline
      feedparakeet
      I think it will be really cool to have a module which will render a graph from the values you provide. Let’s say it will be a txt file or url with values put into rows. So the module will grab last N rows and render a graph.
      All ideas I have for now is to create a transparent graph image myself and import it with the RandomPhoto module.
      Im wondering do anyone here tried to create a custom graph for MM?
        roramirez Core Contributors
        There a module of @qistoph
        [card:qistoph/MMM-dynchart]
        Easy module development with MagicMirror Module Template
        F 1 Reply Last reply Reply Quote 1
        • F Offline
          feedparakeet @roramirez
          @roramirez said in Graph module:
          Thank you! Yes, it looks pretty much like what Im looking for. But I could make a guess only throw the source code, because I could not make this module run. And it draws a static graph, not dinamic
          • Q Offline
            qistoph
            Hi @feedparakeet,
            The MMM-dynchart was a sample used to show some ideas.
            A better example for you would be my Vitadock module:
            https://github.com/qistoph/MMM-vitadock
            Maybe you can use it to base your module on.
            If you could give a more detailed description of what you what to graph, I might be able to help you.
              d3r
              I’m logging room temperature and humidity to a csv file. How would I go about using the data to graph it to my mirror?
              • PointPubMediaP Offline
                PointPubMedia
                I’m using a bunch of graph already… why not using Grafana to record the data and the iFrame module to display them in your MM ?
                D F 2 Replies Last reply Reply Quote 0
                  d3r @PointPubMedia
                  @PointPubMedia said in Graph module:
                  That’s a good idea actually. I don’t know what grafana is, will look into it. I might just use the temperature logging python code I have and add a graphing portion to it as well and then use the iframe module to display the graph. Sounds feasible on paper.
                  • F Offline
                    feedparakeet @PointPubMedia
                    @PointPubMedia, thanks, Grafana looks good. I have it installed now to graph server’s cpu, network, e.t.c… Could you tell me please what do you use as a data source for Grafana to create custom graphs? I want to create bitcoin-usd graph, but I don’t know how can I put a data into Grafana.
                    And how do use put Grafana’s graph into iFrame module? Are there any tricks you can share?
                    PointPubMediaP 1 Reply Last reply Reply Quote 0
                      PointPubMedia @feedparakeet
                      @feedparakeet I disable the authentication in Grafana so I can use direct link to a graph without a username/password!
                      In grafana, you can “export” a graph and it will give you a direct URL that you can use directly in an iFrame!
                      For datasource, currently I’m using a module in my home automation that already send data to grafana!
                      I need to work later on some unix script to send data directly in grafana!
                      • F Offline
                        @PointPubMedia Thanks! It worked!
                        Final setup is: php scripts which grab info from fixer.io (eur + usd) and btc-e.com (bitcoin), put them to InfluxDB and display with Grafana. Works like a charm!
                        Here is a screenshot from my MM. Looks beautiful in general. But still, few minor things to work on.
                        • 1 / 3
