MMM-GoogleSheets not working
5 Posts 3 Posters 862 Views 3 Watching
    SARCux
    Hi @all,
    MMM-GoogleSheets not running,
    i do all of step1 in the readme, but the module is not running.
    all other modules after that will not be loaded.
    This message displayed in Chrome
    TypeError: Cannot read property '0' of undefined (Zeile 11, Datei "Code")
    It seems to be a problem with Google, right? Can someone help
      sdetweil
      @SARCux this module needs the request library but doesn’t have a package.json
      did u already do this
      S 1 Reply Last reply May 16, 2022, 6:05 PM Reply Quote 0
        SARCux @sdetweil
        Thx for this information,
        but I’ve already done that.
        You may remember the other issue where the calendar wasn’t showing and I was able to fix it with that.
        S 1 Reply Last reply May 17, 2022, 2:18 AM Reply Quote 0
          sdetweil @SARCux
          @SARCux i see the same problem…
          looks like google changed the process
          you’ll have to post an issue in the module’s github site
          R 1 Reply Last reply Aug 10, 2024, 2:53 PM Reply Quote 0
            ryandwilliams @sdetweil
            @sdetweil In case anyone finds this post in the future.
            This problem is usually one of two causes:
            1. The google apps script was not deployed correctly and the request runs into a permission error page
            2. There is an error in the request due to bad script URL or other parameter
            I have updated the module to fail gracefully in these cases and hopefully provide a better error message. If you are still having problems feel free to add an issue to the repo. (https://github.com/ryan-d-williams/MMM-GoogleSheets/issues).
