    Wanting to do it the right way (revisited)
    3 Posts 2 Posters 1.9k Views 2 Watching
      Now that I have my MM built and operational (you can see it in the “Show your mirror” forum - and please comment) I want to perfect the way I’ve done my editing. I’ll explain:
      For example, a portion of my config.js file reads as follows:
      module: ‘weatherforecast’,
      position: ‘top_right’,
      header: ‘Weather Forecast’,
      locationID: ‘5128581’, //ID from http://www.openweathermap.org
      appid: ‘This is where my API key goes’
      And a portion of my weatherforecast.js file reads:
      // Default module config.
      defaults: {
      locationID: 5128581,
      appid: “Im an idiot for posting my API key last time”,
      units: config.units,
      maxNumberOfDays: 10,
      showRainAmount: false,
      updateInterval: 10 * 60 * 1000, // every 10 minutes
      animationSpeed: 1000,
      timeFormat: config.timeFormat,
      lang: config.language,
      fade: true,
      fadePoint: 0.25, // Start on 1/4th of the list.
      initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
      retryDelay: 2500,
      apiVersion: "2.5",
      apiBase: "http://api.openweathermap.org/data/",
      forecastEndpoint: "forecast/daily",
      appendLocationNameToHeader: true,
      calendarClass: "calendar",
      roundTemp: true,
      My question is this: Was I supposed to bring the settings in the weatherforecast.js file into the config.js file? Everything works fine but what is the right way of doing it? It would be easier to edit them if they were combined into the config.js file instead of bouncing back and forth between .js files. Or, are they supposed to remain separate?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Mykle1
        @Mykle1 dont make changes in the module files
        only add the part to the config that you want to be different than the defaults
          Mykle1 Project Sponsor Module Developer @strawberry 3.141
          @strawberry-3.141 said in Wanting to do it the right way (revisited):
          That’s what I wanted to know, thanks.
