    Can MagicMirror run on other similarily priced hardware?
    21 Posts 10 Posters 9.9k Views 10 Watching
      redink
      Raspberry Pi is sold out everywhere. I’d like to build another MagicMirror, but don’t want to shell out $150 to a scalper for the hardware. Can I run this software on anything else?
      S X 2 Replies Last reply Reply Quote 0
        sdetweil @redink
        @redink sure, will run on almost anything
        I run on Chromebox w gallium, odroid xu4, Jetson nano, PC w Ubuntu, laptop w windows.
        macos, Chromebook w gallium (using camera and mic)
        if debian based , or Mac, my install script will figure it out, or I will fix script
        R plainbrokeP 2 Replies Last reply Reply Quote 1
          redink @sdetweil
          @sdetweil, that’s great to know. I will see what I can find.
          • X Offline
            xIExodusIx @redink
            @redink
            Hi, I bought my Rasberry Pi 3 B+ last Week at Kiwi Electronics Netherland (www.kiwi-electronics.com), it cost me including shipping about 57,-- Euro.
            Maybe this Info can help you.
            xIExodusIx
            N6NGN 1 Reply Last reply Reply Quote 0
            • N6NGN Offline
              N6NG @xIExodusIx
              @xIExodusIx said in Can MagicMirror run on other similarily priced hardware?:
              There out also…
              Dennis
              N6NGN X 2 Replies Last reply Reply Quote 0
              • N6NGN Offline
                N6NG @N6NG
                @N6NG How about running it on a Arduino? If they can be found…
                • X Offline
                  xIExodusIx @N6NG
                  @N6NG
                  Sorry :-(
                    sdetweil @N6NG
                    @N6NG no, not Arduino…
                    • BKeyportB Offline
                      @sdetweil That would be something, wouldn’t it?
                      Getting enough backend running on any Arduino based unit (like a Wemos-d1 clone, so it has networking) to run Magic Mirror. Talk about an embedded project!
                      • N6NGN Offline
                        N6NG @BKeyport
                        @BKeyport No wonder you can still by those at a reasonable price… I guess it’s bite the bullet and pay full price for a Pi4 is the only answer…
                        • BKeyportB Offline
                          BKeyport Module Developer @N6NG
                          @N6NG think iOS vs AndroidOS.
                          Pi (iOS side) does all their own production, and nobody else copies it for their own products. The hardware is locked down somewhat.
                          Arduino (AndroidOS side) which is covered on a literal poo-ton of products, so you can get Arduino built into anything - causing a constant glut of hardware and pretty much continuous production.
                            stickymongoose
                            I kept an eye on RPiLocator when I was getting my home assistant setup going. It took a couple of weeks for one to come into stock (UK) but I got one in the end.
                            • P Offline
                              paymerich
                              http://www.orangepi.org/
                              https://banana-pi.org/
                              Try a OrangePi or BannaPi . There may be a long lead time but they basically are Raspberry pi clones.
                              • plainbrokeP Offline
                                plainbroke @sdetweil
                                @sdetweil said in Can MagicMirror run on other similarily priced hardware?:
                                gallium
                                That looks like a very good option while the Raspberry Pi are so expensive.
                                I just bought a refurbed chrome book that is in the list supported by gallium.
                                Going to give gallium a try when it arrives.
                                Do you know if I could just load debian on the chrome book?
                                I want to try a few different programs and they all require Debian or Ubuntu…
                                S mumblebajM 2 Replies Last reply Reply Quote 0
                                  sdetweil @plainbroke
                                  @plainbroke I’m not aware of a different port that supports Chromebook/box
                                  I have both Chromebook and Chromebox running gallium, w mm installed.
                                  u have to open the case and remove the write protect screw and burn a different bios to install anything other than chromeos.
                                  plainbrokeP 1 Reply Last reply Reply Quote 0
                                  • mumblebajM Online
                                    mumblebaj Module Developer @plainbroke
                                    @plainbroke I don’t know if they ship overseas but you could try and find out from them. https://www.pishop.co.za/store/raspberry-pi-3
                                      MMRIZE
                                      I prefer Khadas VIM series, Just one of the thinnest form factors(11.5mm), which has enough ports. There definitely exist so many smaller SBCs but they do have not enough connectivities and power as Khadas VIM series.
                                      You can make your MagicMirror thinner. (as long as you need it…)
                                      https://www.khadas.com/
                                      • mumblebajM Online
                                        mumblebaj Module Developer @MMRIZE
                                        @MMRIZE They are a bit pricey I would say but looks good.
                                          Will MM run on Libre Computer Board AML-S905X-CC (Le Potato) 2GB 64-bit Mini Computer they are only $55 on amazon. I think they will run Debian pretty easily.
                                          I am going to try a few other projects with it that I have been wanting to do on a RPi, but they are pretty pricey right now. I thought this was worth a try. If it doesn’t work out, I will try a few of the projects on the support forum they have.
                                            @plainbroke if they run debian, then you should have everything.
                                            need a browser and nodejs.
                                            looks like they are fairly stagnant tho, last os updates in 2019
                                            https://libre.computer/products/s905x/
                                            Ubuntu 18.04, where current is 22.04
