    Default weather module not showing after MM update
    25 Posts 7 Posters 9.3k Views 7 Watching
    • 0 Offline
      01ZerosOnes01 @mumblebaj
      @mumblebaj Okay this is what I get when I run shift + ctrl + i
      Load script: modules/default/weather/weather.js
      :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
      Jarhead96097J S B T 4 Replies Last reply Reply Quote 0
      • Jarhead96097J Offline
        Jarhead96097 @01ZerosOnes01
        @01ZerosOnes01 said in Default weather module not showing after MM update:
        I’m receiving the same error after updating to 2.20.0. Here’s the text from the weather.js error line 159: " currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,(RED X)"
        Jarhead96097
        0 1 Reply Last reply Reply Quote 0
        • 0 Offline
          01ZerosOnes01 @Jarhead96097
          @Jarhead96097 Thanks for your info. Hopefully someone can come up with the fix.
            sdetweil @01ZerosOnes01
            @01ZerosOnes01 @Jarhead96097
            how did u upgrade,and from what version?
            I don’t see any significant code change here this release…
            Jarhead96097J 1 Reply Last reply Reply Quote 0
            • 0 Offline
              01ZerosOnes01
              I keep the mirror updated so I am assuming it was updated from the last version.
              I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
              followed by git stash apply
              All other default and third party modules work.
              Thank for your help it is appreciated.
              • mumblebajM Offline
                mumblebaj Module Developer @01ZerosOnes01
                @01ZerosOnes01 I had my API authorized and the module works just fine with your location data. The only change I made was not add quotes around the locationID.
                locationID: 4891010,
                  Jarhead96097 @sdetweil
                  @sdetweil I also upgraded from 2.19.0, which had been upgraded from 2.18.0. No problems before today.
                  Jarhead96097
                    Jarhead96097 @mumblebaj
                    @mumblebaj Well, unfortunately, removing the quotes around locationID did not resolve the issue on my configuration. I still receive “Uncaught SyntaxError: Unexpected token” in weather.js:159.
                    Jarhead96097
                    • 0 Offline
                      01ZerosOnes01
                      Raspberry Pi 4 2GB
                      Well this is what i have done so far.
                      Removed SD card with broken default weather module.
                      With new SD card installed fresh 64bit Pi OS
                      Fresh manual install of MagicMirror
                      “name”: “magicmirror”,
                      “version”: “2.20.0”,
                      “description”: “The open source modular smart mirror platform.”,
                      “main”: “js/electron.js”,
                      Entered my openweathermap credentials
                      and
                      Walla! the weather module works.
                      I have no idea why the weather module broke after the MagicMirror update. I will be following this thread to see if it is a problem or it was just a fluke.
                      Good luck and thanks to all that contribute.
                      Now I just have to reload my third party modules and customizations.
                        @01ZerosOnes01 @sdetweil Glad to hear you’re up and running on a fresh install… I’m hoping to avoid having to rebuild mine. Any other thoughts?
                        And thanks for your time in advance!
                        Jarhead96097
                        S 0 2 Replies Last reply Reply Quote 0
                        • 2 / 3
