    Default weather module not showing after MM update
    25 Posts 7 Posters 9.4k Views 7 Watching
      sdetweil @Jarhead96097
      @Jarhead96097 would be interested in knowing if my upgrade script avoided this problem
      FoziF 1 Reply Last reply Reply Quote 1
        Bearded1ne253 @01ZerosOnes01
        @01ZerosOnes01 you do not have a “ to start your string, only one at the end…
        • 0 Offline
          01ZerosOnes01 @Jarhead96097
          @Jarhead96097 I was lucky I had a backup of my config. So just a reinstall and copy and paste. Everything is working fine now.
          All the best.
          • FoziF Offline
            Fozi Project Sponsor @sdetweil
            @sdetweil I updated with your script and had no issues at all. Everything is fine.
            • T Offline
              Trabi11 @01ZerosOnes01
              @01ZerosOnes01 said in Default weather module not showing after MM update:
              @mumblebaj Okay this is what I get when I run shift + ctrl + i
              Load script: modules/default/weather/weather.js
              :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
              I’m running into the exact same issue as explained above since I updated my MM.
              However, I only get this error message in chromium on the rasperry pi itself when I call the URL of the MM. All other devices in my network can display the Weather Module cleanly when I access the page via LAN IP. Both chromium and firefox on my notebook and my smartphone are displaying the default weather module cleanly.
              • 3 / 3
