    Automatically terminate the process after NPM Run serve
    10 Posts 3 Posters 2.6k Views 3 Watching
    • 史 Offline
      史新瑞
      Hello everyone, after NPM run serve you need CTRL + C or something to stop the process, but I want it to stop automatically, what should I do
      史 plainbrokeP 2 Replies Last reply Reply Quote 0
      • 史 Offline
        史新瑞 @史新瑞
        @史新瑞 npm run serve This command
          sdetweil @史新瑞
          @史新瑞 use pm2 to launch the process
          my scripts, provide pm2 control, and using the installers/mm.sh
          which u can change to just launch server mode
          then you can pm2 start,stop, restart the defined process
          see https://github.com/sdetweil/MagicMirror_scripts
          fixuppm2
          last link on the page
          the script sets up to launch the app at boot time as well, and pm2 will restart any app that fails…
          史 2 Replies Last reply Reply Quote 0
          • 史 Offline
            史新瑞 @sdetweil
            @sdetweil Can you do this by modifying the serve.js file or the main.js file
              sdetweil @史新瑞
              @史新瑞 you do not touch our .js files…
              just change the mm.sh to
              npm run serve
              instead of
              npm start
              then everything is the same
              MagicMirror ‘app’ to pm2 is ~/MagicMirror/installers/mm.sh
              pm2 start MagicMirror
              pm2 stop MagicMirror
              pm2 restart MagicMirror
              on reboot
              pm2 starts MagicMirror
              • 史 Offline
                史新瑞 @sdetweil
                @sdetweil I am a Chinese and my English is not very good. I can only communicate with you through translation software. I am very glad to meet you and honored to get your guidance
                  sdetweil @史新瑞
                  @史新瑞 understand… I cannot speak or read Chinese either!..
                  史 1 Reply Last reply Reply Quote 0
                  • 史 Offline
                    史新瑞 @sdetweil
                    @sdetweil Thank you. I’ll try it now
                    • plainbrokeP Offline
                      plainbroke @史新瑞
                      @史新瑞 said in Automatically terminate the process after NPM Run serve:
                      Try putting a space then & that works for me on a couple of different projects I am running. Like my DHCP server Hope it helps.
                      • 史 Offline
                        史新瑞 @plainbroke
                        @plainbroke Thank you
