    Display the specified picture in the specified location
    11 Posts 3 Posters 4.5k Views 3 Watching
    • 史 Offline
      史新瑞
      I want to display the specified image in the middle of the screen. What should I do
        sdetweil @史新瑞
        @史新瑞 I answered this in another post you made.
        please don’t multipost the same question
        plainbrokeP 史 2 Replies Last reply Reply Quote 0
        • plainbrokeP Offline
          plainbroke @sdetweil
          @史新瑞
          Here is what I use in my config.js file, for an example:
                  module: "MMM-ImagesPhotos",
                  position: "middle_center",
                          opacity: 0.9,
                          animationSpeed: 500,
                          updateInterval: 10000,
                          backgroundColor: "black",
                          maxWidth: "500px",
                          maxHeight: "500px",
                          fill: false
          Hope this is what you where looking for. I find and example really helps me figure out what I am doing wrong or in some cases what I am doing correct.
          S 史 2 Replies Last reply Reply Quote 0
            sdetweil @plainbroke
            @plainbroke are you using my version, or the original?
            plainbrokeP 2 Replies Last reply Reply Quote -1
              original I think https://github.com/roramirez/MMM-ImagesPhotos
              Didnt know you had one. i usually stick with what i know.
                What are the differances? Maybe switching to yours would let me run a second one again. I used to have one that shows my grandkids and the other our dogs past and present Now I can only get one to run at a time.
                Probably need to do some reading about running multiple versions…
                  @plainbroke I give u the option to fill around the picture, color or a blurred version of the pic.
                  this module doesn’t support multiple instances
                  and the copy/rename won’t work either
                  plainbrokeP 1 Reply Last reply Reply Quote 0
                  • 史 Offline
                    史新瑞 @plainbroke
                    @plainbroke Does the module “MMm-Imagesphotos” need to be redefined? Or does ㎜ itself contain the module
                      sdetweil @史新瑞
                      @史新瑞 you have to install it separately…
                      see the two topics in my signature below
                      and the 3rd party list
                      https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules
                      not all are listed here.
                      • 史 Offline
                        史新瑞 @sdetweil
                        @sdetweil Sorry
                          @sdetweil said in Display the specified picture in the specified location:
                          Bummer Sam.
                          I installed yours and it worked without changing anything in my config.
                          I was hoping to fool it into working as a double…
