    Possible to show Month View in lower corner?
    14 Posts 6 Posters 4.4k Views 5 Watching
    • Cliff365C Offline
      Cliff365
      Currently, I am only using core features, but I’m fine with using a third party if I need to. What I would like is to display a small month view in the lower corner of the screen. Is this possible somehow?
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @Cliff365
        @Cliff365 the core module doesn’t show a view like that… you would have to use something like CalendarExt3
        the base shows for the next n days… (default 10)
        Cliff365C 1 Reply Last reply Reply Quote 0
        • Cliff365C Offline
          Cliff365 @sdetweil
          @sdetweil said in Possible to show Month View in lower corner?:
          CalendarExt3
          Thanks. I’ll take a look.
            MMRIZE @Cliff365
            @Cliff365
            CX3 has no small view of the month. (Previous CX2 has MMM-CalendarExtMinimonth plugin), Sorry.
            Cliff365C 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @Cliff365
              @Cliff365 Look at MMM-Multimonth. https://github.com/BKeyport/MMM-Multimonth - it’s a plain calendar in small mode.
              • Cliff365C Offline
                Cliff365 @MMRIZE
                @MMRIZE Also good to know. Thanks!
                • ? Offline
                  A Former User
                  This post is deleted!
                  • BKeyportB Offline
                    BKeyport Module Developer @Guest
                    Wow. That’s almost insulting to have all the modules ripped and reuploaded there with no mention of the original authors. (yeah, it’s a free project, with MIT licenses, but still…)
                    … Good to know it’s there, though.
                    FWIW, for anyone else doing this kind of thing - it would be better to fork off the original, then do your work on the module as you’d like, and then if you think it would be beneficial to all, ask for it to be added to the main work.
                    The module tree @hango pointed out is several versions old, and totally out of sync with current releases - putting your work at risk. For example, my module uses moment.js - which is dead. I’m reworking it at this time to do something else instead, as moment.js is also known to have several security issues.
                    Fork, Fix, and request merge. Bottom line. If the original author don’t respond, people can find yours and use it. There’s really no downside to doing it that way.
                      sdetweil @BKeyport
                      @BKeyport great advice, for the willing.
                      as I recall, there are a number of developers that believe they can do it all differently and better, and choose not to share, or contaminate their version with other sources.
                      kayakbabeK 1 Reply Last reply Reply Quote 1
                      • kayakbabeK Offline
                        kayakbabe @sdetweil
                        @sdetweil I agree with Sam or the dev ends up rewriting so much that it really isn’t mergable at all. Perhaps renaming and just a comment mentioning the idea came from so-and-so is better solution.
                        • BKeyportB Offline
                          BKeyport Module Developer @kayakbabe
                          @kayakbabe Thing is, if someone came up with some grand way to redo, say, the positioning system on Magic Mirror (yes, it’s one of the ones in that tree), I’m sure MichMich would love to know about it and possibly figure out how to incorporate it into the main project, even if it’s not compatible at the moment.
                          That’s actually how my product got to it’s current potential - If it wasn’t for Volker Wegert re-working a ton of it, and my basically scrapping my code and using his fork, MMM-Multimonth would still be on the shelf - which is why I show him the respect of thanks and co-author in the notes.
                          Lots of work still to do, and I’m still working on it, even if my depression kicked in and said no.
                          kayakbabeK 1 Reply Last reply Reply Quote 0
                          • Cliff365C Offline
                            Cliff365 @MMRIZE
                            @MMRIZE MMM-CalendarExtMiniMonth is exactly what I’m looking for. Thanks!
                              kayakbabe @BKeyport
                              @BKeyport Your idea of the positioning system improvement is very interesting. I would at the least like to be able to insert subdivisions of middle_center and the others that are full width.
                              In my case, I would like to have middle_center_left, middle_center_middle, middle_center_right. Perhaps we can insert into the DOM to create them and then delay loading of any module that is assigned to the location. Perhaps there is a way to manually handle that already, but I’ve not bothered yet. perhaps adding flex to the css of of middle_center would be sufficient. I suppose that is a bridge I will cross when I arrive there.
                              • BKeyportB Offline
                                @kayakbabe wasn’t a ‘idea’ so much as a passive aggressive point.
                                I’ve previously asked to add middle to the left and right to make it a true 3x3 grid for top/middle/bottom and left/center/right.
