    How to properly update modules?
    12 Posts 4 Posters 6.1k Views 4 Watching
    • Cliff365C Offline
      Cliff365
      I get a message that MMM-Multimonth and MMM-Wallpaper need updating.
      I open a console window, go into each module folder and enter:
      git pull
      npm install
      No errors. I restart MM and no message. After a few hours the messages are back as if I never updated them.
      I must be doing something wrong.
      S qu1queQ 2 Replies Last reply Reply Quote 0
        sdetweil @Cliff365
        @Cliff365 tell us more. what environment are you using? pi w raspi os, mmos, docker?
        Cliff365C 1 Reply Last reply Reply Quote 0
        • Cliff365C Offline
          Cliff365 @sdetweil
          @sdetweil Oops. Raspberry Pi 3b+. Just recently did the update using:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          The update completes without an error.
            sdetweil @Cliff365
            @Cliff365 when in the module folder and u do git pull, does it complete ok?
            • qu1queQ Offline
              qu1que Project Sponsor @Cliff365
              @Cliff365
              Hi, today I have an update on MMM-Wallpaper module too. I updated it using git pull && npm install. A few hours later, I had another update, so I repeated the process. I think it’s not an error. I think it’s the module developer that is making some changes to the code.
              Try to check if the response on the terminal is always the same when updating or if they are different. In the case I just told you about, the updates were different.
              • Cliff365C Offline
                Cliff365 @qu1que
                @qu1que You may be right. I’m getting this for MMM-Wallpaper.
                This one for MMM-Multimonth
                  sdetweil @Cliff365
                  @Cliff365 those are from the npm install
                  you can turn off with --no-audit
                  so, the git pull worked ok…
                  if you do it again it should say up to date
                  • BKeyportB Offline
                    To be fair, for MMM-Multimonth I did a pair of updates nearly back to back. Screwed up the first one. Update was very minor, you shouldn’t have to re-run NPM Install with it.
                    As for the security vulnerability - I’m aware… Been trying to re-code around it (It’s moment.js - getting rid of it)
                      sdetweil @BKeyport
                      @BKeyport u can just turn off the warning, save grief… this is not a general web page that 1000’s will visit…
                      npm install --no-audit --omit=dev
                      (updated install and upgrade to do this, stop users from doing dumb audit which screws things up)
                      • BKeyportB Offline
                        @sdetweil yeah, well… Like I said, I’m re-writing code anyway. Moment is dead. Might as well bury it.
                          sdetweil @BKeyport
                          @BKeyport in a few decades maybe…
                          i’m not rewriting any of mine…
                          • BKeyportB Offline
                            @sdetweil hey, I’m trying to be as good as @mmrize let me be. 🤣🤣
