    Change page with MMM-Pages
    25 Posts 3 Posters 11.6k Views 3 Watching
    • E Offline
      Egnos @MMRIZE
      @MMRIZE said in Change page with MMM-Pages:
      See how usage looks like.
      https://youtu.be/BcpZvkcrfHU
      I just have to try!
      @MMRIZE If instead you took the sensor without a cover how did you think of attaching it to the frame? Do you leave the sensor naked or cover it with a self made cover?
        MMRIZE @Egnos
        @Egnos
        At this moment, I don’t have the real implementation to show,
        But what I tried was;
        Dig a hole then Implant the sensor in the frame. This gesture sensor has a short distance, but fortunately, through thin plastic/acryl/wood/paper/glass, it works. It detects changes in magnetic fields so except for metal/mirror(metal coated) it will work.
        My first intention was to cover the hole with small cardboard paper, then paint it black (I prefer a black framed mirror), But I lost interest at the finish stage, so I left it naked. :D
        • E Offline
          Egnos @MMRIZE
          Hi @MMRIZE unfortunately behind wood, plastic or plexiglass the sensor does not work … it’s a big problem!
          Do you know by chance if this sensor has a SW adjustment (I don’t see any trimmer on the PCB …)?
          thanks
            MMRIZE @Egnos
            @Egnos
            By my test, under 5mm thick plastic or wood panel it works. But there is no s/w fixture about it.
            • E Offline
              Egnos @MMRIZE
              I did several tests and even a piece of paper in front of it doesn’t work … it must be completely free …
              I should try the glass …
