    Bluetooth timeout in Raspberry
    6 Posts 3 Posters 1.3k Views 3 Watching
    • E Offline
      Egnos
      Hello people!
      I connected the Raspberry bluetooth to a bluetooth speaker (Nest Audio speaker …).
      It works well but unfortunately it disconnects after a certain time of inactivity.
      It’s annoying because I always have to restore the bluetooth connection.
      Do you know a way to disable this timeout?
      Thank you all.
      S R 2 Replies Last reply Reply Quote 0
        sdetweil @Egnos
        @Egnos maybe,it’s 5 years old. but the term is idle timeout
        https://stackoverflow.com/questions/46710890/bluetoothctl-pairing-timeout-on-raspberry-pi-3/46805952#46805952
        • E Offline
          Egnos @sdetweil
          @sdetweil said in Bluetooth timeout in Raspberry:
          Inside the “Input.conf” file he writes that "IdleTimeout"is already set to 0.
          I however uncommented the line and put it at 0, let’s see if it solves … but I doubt!
          # Configuration file for the input service
          # This section contains options which are not specific to any
          # particular interface
          [General]
          # Set idle timeout (in minutes) before the connection will
          # be disconnect (defaults to 0 for no timeout)
          #IdleTimeout=30
          IdleTimeout=0
          # Enable HID protocol handling in userspace input profile
          # Defaults to false (HIDP handled in HIDP kernel module)
          #UserspaceHID=true
          # Limit HID connections to bonded devices
          # The HID Profile does not specify that devices must be bonded, however some
          # platforms may want to make sure that input connections only come from bonded
          # device connections. Several older mice have been known for not supporting
          # pairing/encryption.
          # Defaults to false to maximize device compatibility.
          #ClassicBondedOnly=true
          # LE upgrade security
          # Enables upgrades of security automatically if required.
          # Defaults to true to maximize device compatibility.
          #LEAutoSecurity=true
            sdetweil @Egnos
            @Egnos and then rebooted yes?
            • E Offline
              Egnos @sdetweil
              @sdetweil Yes…but nothing changes … also because “IdleTimeout” is by default at 0…
              I am testing a script that I launch every 15min using the “crontab” function.
              I will report the test result and share the script here on the forum.
                Rags @Egnos
                @Egnos said in Bluetooth timeout in Raspberry:
                Hello people!
                Thank you all.
                Hello,
                iam trying to connect Rpi-3B to alexa dot , not happening. How to do it. Thanks
