    updating module not possible...need help
    13 Posts 4 Posters 4.2k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      error: Your local changes to the following files would be overwritten by merge:
      	.DS_Store
      Please commit your changes or stash them before you merge.
      Aborting
      S AssassinsA 2 Replies Last reply Reply Quote 0
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil my solution is to delete the module folder and do a new install and that’s it
        thanks to all
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe interesting
          this on a Mac?
          rm .DS_store
          then git pull again
            @sdetweil yes on a mac and on pi too
              @Stoffbeuteluwe .DS_Store is a Mac file
              I would guess it was added to the git repo accidentally
              • BKeyportB Offline
                Alert the module author so they can work with you to determine if the file is in the repo and have it removed so it don’t cause issues.
                  sdetweil @BKeyport
                  @BKeyport it IS in the repo, else u wouldn’t get that error on pull
                  • BKeyportB Offline
                    @sdetweil doh. you’re right. Silly me. ;)
                    • AssassinsA Offline
                      Assassins @Stoffbeuteluwe
                      @Stoffbeuteluwe
                      I do this on my mac to pi : https://docs.magicmirror.builders/getting-started/upgrade-guide.html
                      and it work
                        sdetweil @Assassins
                        @Assassins run my upgrade script
                        StoffbeuteluweS AssassinsA 2 Replies Last reply Reply Quote 0
                          thanks to all
                            @Stoffbeuteluwe no point doing all that, but it works too
                              Assassins @sdetweil
                              @sdetweil why ??? The otter work 100% here.
                                sdetweil @Assassins
                                @Assassins if you are going to delete the directory, and clone, u might as well delete one file and install…
