    Font-awesome
    16 Posts 2 Posters 4.4k Views 2 Watching
    • B Online
      bicolorbore586
      Hi all,
      Looking at modifying the MMM-BIRTHDAYS to display a birthday cake icon.
      I’ve added symbol: ‘birthday-cake’, to the config.js file along with
      getStyles: function () {
      return [“font-awesome.css”];
      but this doesn’t appear to work. I’ve tried comparing to calendar.js etc but to no avail.
      Any help / guidance (in simpletons language), would be greatly appreciated.
        sdetweil @bicolorbore586
        @bicolorbore586 open the developers window, ctrl-shift-i, and select the console tab
        add part of the module name to the filter field to get just those messages
        u can examine the web content too. to make sure the icon name is specified correctly
        see also
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1665064979567
        • B Online
          bicolorbore586 @sdetweil
          Hi Sam, thanks for taking the time to reply, having looked at the developer window I have the below… doesn’t appear to show any issues.
            @bicolorbore586 ok, can u look at the html to make sure the icon name is specified?
            see the prior link about navigating the elements content
              @bicolorbore586 where is that module located… google search didn’t find it
              • B Online
                @sdetweil I copied and pasted the icon logo from font-awesome cheat sheet.
                The module is https://github.com/marcomerens/anniversarymodule
                  @bicolorbore586 ok, I added the content to the njk, and it came up
                  add th too
                                         			<th> </th>
                                         			<th>Name</th>
                  			<td><span class="fas fa-fw fa-birthday-cake"/></td>
                  			<td>{{p.name}}</td>
                  			<td>{{p.date}}</td>
                  • B Online
                    @sdetweil Copied and pasted the code and I get the below 29368d2e-22bc-4a73-9588-cf7df46f6846-image.png
                    Questions…
                    Do I need to add each persons name to where it says {{p.name}}
                    Does it matter where in the .njk code I put the text?
                      @bicolorbore586 the names are in config.js , see the doc
                      where ? no… do u want it on the person
                      • B Online
                        @sdetweil Yeah the config.js is all set up.
                        I would like it a inn the screen shot you posted where you have
                        Cake Icon Steve 25 Nov 50
                        Cake Icon Marco 30 Dec 85
                        Similar to the calendar, but the birthday cake instead of calendar icon.
                        S 3 Replies Last reply Reply Quote 0
                          @bicolorbore586 eh? mine shows the cake on each row
                            @bicolorbore586 i just pasted the sample config from the doc into the config.js no changes
                            has two names/rows
                              @bicolorbore586 I think u said u want it on the row
                              then it DOES matter where u put it…
                              it has to be on the TABLE ROW
                              like my code
                              inside the <tr>     ---- row
                              is a column <th>   ---- header
                              and data for column <td> ---  column data
                              • B Online
                                @sdetweil so, I now have the icon in each row, but it fills the name column and shifts the name to the date, date to days and pops the days on the end… (sorry absolute noob at this, trying to move things around, but can’t for the live of me see how to change it).
                                {% for p in people.slice(0,limit) %}
                                	<tr>
                                {% if p.days == 0 %} {% else %} {% endif %} {% endfor %}
                                Name Date Days
                                {{p.name}} {{p.date}}Today{{p.days}}
                                  @bicolorbore586 u didn’t add a column to the table header
                                  see my code which has a new th
                                  • B Online
                                    @sdetweil got ya!
                                    I hadn’t created the column in the right place.
                                    Thanks for your patience and guidance.
