    MMM-Remote-Control actually
    7 Posts 3 Posters 1.6k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hi, is this module MMM- Remote-Control from Jopyth actually?
      https://github.com/Jopyth/MMM-Remote-Control
      or must i take this here:
      https://github.com/Klettner/MM-Remote
      Because i installed the module from Jopyth but when i pu the http://ipfrom raspi:8080/remote.html its no connection :_(
      This is my config:
          module: 'MMM-Remote-Control',
          // uncomment the following line to show the URL of the remote control on the mirror
          // position: 'bottom_left',
          // you can hide this module afterwards from the remote control itself
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              apiKey: "'xxxxxxxxxxxxxxxxxxxx", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
      and
      config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.200.1/120", "192.168.200.1/24"], 	// Set [] to allow all IP addresses
      best regards
      S BKeyportB 2 Replies Last reply Reply Quote 0
      • kusselinK Offline
        kusselin
        You are so great sdetweil :-)
        so ist running:
        config = {
        	address: "0.0.0.0", 	// Address to listen on, can be:
        	port: 8080,
        	ipWhitelist: [], 	// Set [] to allow all IP addresses
        thanks a lot again to you
          sdetweil @kusselin
          @kusselin said in MMM-Remote-Control actually:
          address: “localhost”,
          this means ONLY apps INSIDE the same system can connect
          SO, you need to change it to allow systems from OUTSIDE the pi to access
          address:"0.0.0.0",
          ipWhitelist:[],
          this means any adapter can hear requests (instead of just the loopback adapter localhost)
          and you are not filtering out client ip addresses
          kusselinK 1 Reply Last reply Reply Quote 0
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil but iam in my own network at home…so i can get this 127.0.0.1
            Or is this wrong?
            • kusselinK Offline
              kusselin
              so ist running:
              config = {
              	port: 8080,
                sdetweil @kusselin
                @kusselin no… localhost means ONLY INSIDE the same machine… (127.0.0.1 is the ip address for localhost)
                phone on wifi accessing MM on pi is a different machine
                the default protection is a mirror hanging on the wall, no one would need to access that from outside the mirror…
                oops remote -control does need
                • BKeyportB Offline
                  BKeyport Module Developer @kusselin
                  @kusselin FYI, Jopyth is the original author.
                  • kusselinK Offline
                    kusselin @BKeyport
                    @BKeyport thanks…
