    MM will not start
    32 Posts 3 Posters 9.5k Views 3 Watching
    • B
      bworch
      I have been having issues updating my MM and modules. I was getting the error below
      “Please, commit your changes or stash them before you can merge.
      Aborting” I could not get anything to work. si I tried this and was able to update everything
      git reset --hard
      git pull
      npm install
      Now my mirror will not stat. I also seem to have 2 instances.
      any ideas, thanks
        sdetweil @bworch
        @bworch if you used my script then
        the instance is labeled MagicMirror
        the other instance , mm is not running and could be deleted
        pm2 delete xx
        pm2 save
        xx is name or number
        now
        let’s fix the mm start problem
        pm2 stop all
        pm2 flush
        pm2 start MagicMirror
        wait 15 seconds
        pm2 stop all
        show the results of
        pm2 logs --lines=50
        B 2 Replies Last reply
        • B
          bworch @sdetweil
          @sdetweil thanks for the info. I will try it and let you know. again thanks
          • B
            bworch @sdetweil
            @sdetweil once I delete the mm instance; can I rename the MagicMirror instance to mm. thanks
              sdetweil @bworch
              @bworch i do not know
              but you could edit the installers/pm2_MagicMirror.json
              (this is how I give the pretty name, not the script name)
              file and change the name to mm (check the paths as well)
                "apps" : [{
                  "name"        : "MagicMirror",
                  "script"      : "/home/pi/MagicMirror/installers/mm.sh",
                  "watch"       : ["/home/pi/MagicMirror/config/config.js"]
              and then do (delete old, add new)
              pm2 delete MagicMirror
              pm2 save
              pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
              pm2 save
              • B
                bworch @sdetweil
                @sdetweil thanks for all your help.
                • B
                  bworch
                  I followed your instructions, and it still will not start. I also restart the pi. this is what I have now.
                  thanks
                  • B
                    bworch
                    I did a pm2 show and this is what I got.
                    thanks
                    • B
                      bworch @sdetweil
                      @sdetweil followed your instructions, still will not start. I have this now.
                      did a pm2 show
                      Reply Quote 1
                        sdetweil @bworch
                        @bworch do
                        pm2 logs --lines=100
                        may be better without pm2 for debug
                        pm2 stop all
                        cd ~/MagicMirror
                        npm start >somefile.txt 2>&1
                        wait 15 seconds
                        ctrl-c
                        edit the somefile.txt
                        B 1 Reply Last reply
                        • B
                          bworch @sdetweil
                          @sdetweil couldn’t get the txt file to show. how would I edit it.
                          Reply Quote 1
                            sdetweil @bworch
                            @bworch nano somefile.txt
                            or whatever text editor you like
                            • B
                              bworch @sdetweil
                                sdetweil @bworch
                                @bworch fun times…
                                cd ~/MagicMirror
                                npm install electron@19.0.15
                                • B
                                  bworch @sdetweil
                                  I thank you for sticking with me.
                                    sdetweil @bworch
                                    @bworch ok, I suggest you run my upgrade script
                                    see https://github.com/sdetweil/MagicMirror_scripts
                                    the upgrade script second pass with
                                    force
                                    instead of apply
                                    • B
                                      bworch @sdetweil
                                      @sdetweil which line
                                      • B
                                        bworch @sdetweil
                                        @sdetweil I accidently ran it as is, I then couldn’t find where to make the change. Sorry
                                          sdetweil @bworch
                                          @bworch
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                          • B
                                            bworch @sdetweil
                                            @sdetweil My VNC terminal when Black, is that normal.
