    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 13.3k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hi, is it possible to install MagicMirro in a LXC Container on Proxmox?
      I installed the sdtweil scipt from his github page…but after i installed in /home and i take this:
      pm2 start magicmirror
      magicmirror@magicmirror-live:~$ pm2 start magicmirror
      [PM2][ERROR] Script not found: /home/magicmirror/magicmirror
      what can i do?
      best regards and thanks a lot
      • kusselinK Offline
        kusselin
        Hi sam,
        This was my Solution Now
        https://forum.iobroker.net/topic/52195/magic-mirror-zusammen-mit-iobroker/173?_=1666207319057
        Crontab
          sdetweil @kusselin
          @kusselin everything is case sensitive
          see the installed pm2 apps
          pm2 status
          pm2 start MagicMirror
          • kusselinK Offline
            kusselin
            i installed it new…and this is comming out:
             bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                    \______/
            install log being saved to /root/install.log
            Installing helper tools ...
            Updating packages ...
            Check current Node installation ...
            Node currently installed. Checking version number.
            Minimum Node version: v16.9.1
            Installed Node version: v16.17.1
            No Node.js upgrade necessary.
            Check current NPM installation ...
            NPM currently installed. Checking version number.
            Minimum npm version: V7.11.2
            Installed npm version: V8.15.0
            No npm upgrade necessary.
            Cloning MagicMirror ...
            Cloning into 'MagicMirror'...
            remote: Enumerating objects: 323, done.
            remote: Counting objects: 100% (323/323), done.
            remote: Compressing objects: 100% (256/256), done.
            remote: Total 323 (delta 64), reused 159 (delta 55), pack-reused 0
            Receiving objects: 100% (323/323), 446.83 KiB | 4.30 MiB/s, done.
            Resolving deltas: 100% (64/64), done.
            Cloning MagicMirror Done!
            Installing dependencies ...
            Dependencies installation Done!
            setting up initial config.js
            Check plymouth installation ...
            plymouth is not installed.
            Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
            install and setup pm2
            bash: line 557: $: command not found
            [PM2][WARN] Applications MagicMirror not running, starting...
            [PM2][ERROR] Error: Script not found: /home/root/MagicMirror/installers/mm.sh
            [PM2] Saving current process list...
            [PM2][WARN] PM2 is not managing any process, skipping save...
            [PM2][WARN] To force saving use: pm2 save --force
            Do you want to disable the screen saver? (y/N)?y
            We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            [PM2] Process successfully started
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 18   │ online    │ 0%       │ 4.0kb    │
            [PM2][WARN] Current process list is not synchronized with saved list. Type 'pm2 save' to synchronize.
             pm2 status
            │ 0  │ MagicMirror        │ fork     │ 48   │ online    │ 0%       │ 57.2mb   │
            │ 0  │ MagicMirror        │ fork     │ 71   │ online    │ 0%       │ 4.0kb    │
            Oh…the MagicMirror is started i see it, but when i get this line in the browser
            192.168.200.74:8080 i dont see the screen :-(
            ping is going:
            ping 192.168.200.74
            Ping wird ausgeführt für 192.168.200.74 mit 32 Bytes Daten:
            Antwort von 192.168.200.74: Bytes=32 Zeit=8ms TTL=63
            Antwort von 192.168.200.74: Bytes=32 Zeit=1ms TTL=63
             MagicMirror² Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
            let config = {
            	address: "0.0.0.0", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            	ipWhitelist: [] 	// Set [] to allow all IP addresses
              sdetweil @kusselin
              @kusselin pm2 logs --lines=50
              not good to install under root
              kusselinK 1 Reply Last reply Reply Quote 0
                sdetweil @kusselin
                @kusselin but if you are running in a container
                the the mm.sh script should be running as server
                as there is no ui on a container
                npm run server
                not
                npm start
                • kusselinK Offline
                  kusselin @sdetweil
                  @sdetweil said in MagicMirror install on proxmox LXC Container?:
                  Hello, thank you for the tips…o.k. under root this is nuicht so good…
                  Again from the beginning…I install ubuntu 22.04 standard in a LXC container. I have also created the container by default. This has also all worked great. After that I started the container.
                  So when I am on the console it is so that I log in with root and pass. But that is not so good.
                  So I have now created a standard user with pass. Habs then times made as on Rasoian with user “pi” udn the default password for it. To test!
                  So, now I log in with user “pi” and the default password…now I stand on the “prompt”
                  login as: pi
                  pi@192.168.200.74's password:
                  Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.35-1-pve x86_64)
                   * Documentation:  https://help.ubuntu.com
                   * Management:     https://landscape.canonical.com
                   * Support:        https://ubuntu.com/advantage
                  Last login: Sat Oct 15 19:06:04 2022 from 192.168.1.236
                  pi@MagicMirror-live:~$ ^C
                  Then I take the script from you here:
                  So and if I then start your script via Console then comes the message “[sudo] password or pi”.
                  pi@MagicMirror-live:~$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                          \______/
                  install log being saved to /home/pi/install.log
                  [sudo] password for pi:
                  But you just said that the installation under “root” (sudo) is not good? Yes what is right now? What do I have to do now?
                  Do I have to insert “su” here then??
                  I don’t have a “sudo” password for pi - how do I create it?
                  Do I have to log in again with “pi” and the default pass and then create a “root” pass for pi?
                  and if I then take the root password from my created LXC container, it always comes “sorry try again”.
                  Sorry, try again.
                  What am I doing wrong here?
                  This is what I do not understand and do not know. Can you please describe me this in understandable sentences briefly how I have to proceed with the installation?
                  Thank you
                  • kusselinK Offline
                    kusselin
                    so installed again under “pi”…
                    Commands executed by you here the result:
                    login as: pi
                    Last login: Sun Oct 16 09:53:33 2022 from 192.168.1.236
                    pi@MagicMirror-live:~$ cd MagicMirror
                    pi@MagicMirror-live:~/MagicMirror$ pm2 start MagicMirror
                    │ 0  │ MagicMirror        │ fork     │ 143  │ online    │ 0%       │ 4.0kb    │
                    pi@MagicMirror-live:~/MagicMirror$ pm2 status
                    │ 0  │ MagicMirror        │ fork     │ 308  │ online    │ 0%       │ 3.0mb    │
                    │ 0  │ MagicMirror        │ fork     │ 363  │ online    │ 0%       │ 4.0kb    │
                    If I now enter the following in the browser (Mozilla) then comes network overrun :-(
                    http://192.168.200.74:8080
                    I don´t know whta i can do :-(
                    her my config
                    /* MagicMirror² Config Sample
                     * MIT Licensed.
                    let config = {
                    	port: 8080,
                    	ipWhitelist: [], 	// Set [] to allow all IP addresses
                    	language: "de",
                    	locale: "de-DE",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "weather",
                    				type: "current",
                    				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				apiKey: "YOUR_OPENWEATHER_API_KEY"
                    			module: "weather",
                    			header: "Weather Forecast",
                    				type: "forecast",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    installed now is MagicMirror here
                    /home/pi/MagicMirror
                    • kusselinK Offline
                      kusselin
                      When everyone have proxmox…please install it and give me feedback how you installed it.
                      Thanks a lot
                        sdetweil @kusselin
                        @kusselin
                        change the script that starts mm from
                        npm start
                        to
                        npm run server
                        a container has no desktop,
                        npm start tries to load the graphical UI using electron.
                        npm run server
                        just starts the server side, for external browsers to access
                        I can’t tell what that error is, but the internet has moved to https connections by default, and many browsers warn when accessing http sites like MagicMirror is running.
                        so you either have to accept the warning, or find a way in the browser to disable to message
                        https setup requires a certificate, which is not free.
                        • kusselinK Offline
                          kusselin
                          hi sdetweil, sorry my Linux knowledge is not good.
                          Can you explain me how to change the script udn where in the script?
                          Is my basic installation but with user “pi” so correct
                            sdetweil @kusselin
                            @kusselin my pm2 setup uses
                            ~/MagicMirror/installers/mm.sh
                            • kusselinK Offline
                              kusselin @sdetweil
                              this standing in my mm.sh
                              cd ~/MagicMirror
                              DISPLAY=:0 npm start
                              an now i must put this into than looks like this
                              cd ~/MagicMirror
                              npm run server
                              so o.k.?
                                sdetweil @kusselin
                                @kusselin said in MagicMirror install on proxmox LXC Container?:
                                cd ~/MagicMirror
                                npm run server
                                no
                                cd ~/MagicMirror
                                npm run server
                                • kusselinK Offline
                                  kusselin
                                  o.k…next try to step and hope i can start the MM
                                  look…
                                  curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                  ## Installing the NodeSource Node.js 18.x repo...
                                  ## Populating apt-get cache...
                                  + apt-get update
                                  Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                                  Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                                  Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                                  Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                                  Fetched 224 kB in 2s (105 kB/s)
                                  Reading package lists... Done
                                  ## Confirming "jammy" is supported...
                                  + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                                  ## Adding the NodeSource signing key to your keyring...
                                  + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                  ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                                  + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                                  + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                                  ## Running `apt-get update` for you...
                                  + apt-get update
                                  Get:1 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                                  Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                  Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                                  Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [775 B]
                                  Fetched 5338 B in 2s (2387 B/s)
                                  ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                                  ## You may also need development tools to build native addons:
                                       sudo apt-get install gcc g++ make
                                  ## To install the Yarn package manager, run:
                                       curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                       echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                       sudo apt-get update && sudo apt-get install yarn
                                  pi@MagicMirror-live:~$ sudo apt-get update && sudo apt-get install yarn
                                  Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
                                  Building dependency tree... Done
                                  Reading state information... Done
                                  Note, selecting 'cmdtest' instead of 'yarn'
                                  The following additional packages will be installed:
                                    python3-cliapp python3-importlib-metadata python3-markdown
                                    python3-more-itertools python3-pygments python3-ttystatus python3-zipp
                                  Suggested packages:
                                    python3-xdg python-markdown-doc python-pygments-doc ttf-bitstream-vera
                                  The following NEW packages will be installed:
                                    cmdtest python3-cliapp python3-importlib-metadata python3-markdown
                                  0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
                                  Need to get 969 kB of archives.
                                  After this operation, 5201 kB of additional disk space will be used.
                                  Do you want to continue? [Y/n] Y
                                  Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-cliapp all 1.20180812.1-4 [44.5 kB]
                                  Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-more-itertools all 8.10.0-2 [47.9 kB]
                                  Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-zipp all 1.0.0-3 [5440 B]
                                  Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-importlib-metadata all 4.6.4-1 [16.2 kB]
                                  Get:5 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-markdown all 3.3.6-1 [68.5 kB]
                                  Get:6 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-ttystatus all 0.38-4 [14.7 kB]
                                  Get:7 http://archive.ubuntu.com/ubuntu jammy/universe amd64 cmdtest all 0.32.14.gcdfe14e-2 [21.9 kB]
                                  Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-pygments all 2.11.2+dfsg-2 [750 kB]
                                  Fetched 969 kB in 1s (911 kB/s)
                                  Selecting previously unselected package python3-cliapp.
                                  (Reading database ... 29455 files and directories currently installed.)
                                  Preparing to unpack .../0-python3-cliapp_1.20180812.1-4_all.deb ...
                                  Unpacking python3-cliapp (1.20180812.1-4) ...
                                  Selecting previously unselected package python3-more-itertools.
                                  Preparing to unpack .../1-python3-more-itertools_8.10.0-2_all.deb ...
                                  Unpacking python3-more-itertools (8.10.0-2) ...
                                  Selecting previously unselected package python3-zipp.
                                  Preparing to unpack .../2-python3-zipp_1.0.0-3_all.deb ...
                                  Unpacking python3-zipp (1.0.0-3) ...
                                  Selecting previously unselected package python3-importlib-metadata.
                                  Preparing to unpack .../3-python3-importlib-metadata_4.6.4-1_all.deb ...
                                  Unpacking python3-importlib-metadata (4.6.4-1) ...
                                  Selecting previously unselected package python3-markdown.
                                  Preparing to unpack .../4-python3-markdown_3.3.6-1_all.deb ...
                                  Unpacking python3-markdown (3.3.6-1) ...
                                  Selecting previously unselected package python3-ttystatus.
                                  Preparing to unpack .../5-python3-ttystatus_0.38-4_all.deb ...
                                  Unpacking python3-ttystatus (0.38-4) ...
                                  Selecting previously unselected package cmdtest.
                                  Preparing to unpack .../6-cmdtest_0.32.14.gcdfe14e-2_all.deb ...
                                  Unpacking cmdtest (0.32.14.gcdfe14e-2) ...
                                  Selecting previously unselected package python3-pygments.
                                  Preparing to unpack .../7-python3-pygments_2.11.2+dfsg-2_all.deb ...
                                  Unpacking python3-pygments (2.11.2+dfsg-2) ...
                                  Setting up python3-ttystatus (0.38-4) ...
                                  Setting up python3-more-itertools (8.10.0-2) ...
                                  Setting up python3-zipp (1.0.0-3) ...
                                  Setting up python3-cliapp (1.20180812.1-4) ...
                                  Setting up python3-pygments (2.11.2+dfsg-2) ...
                                  Setting up python3-importlib-metadata (4.6.4-1) ...
                                  Setting up python3-markdown (3.3.6-1) ...
                                  Setting up cmdtest (0.32.14.gcdfe14e-2) ...
                                  Processing triggers for man-db (2.10.2-1) ...
                                  pi@MagicMirror-live:~$ sudo apt install -y nodejs
                                  The following packages will be upgraded:
                                    nodejs
                                  1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  Need to get 28.5 MB of archives.
                                  After this operation, 52.4 MB of additional disk space will be used.
                                  Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.11.0-deb-1nodesource1 [28.5 MB]
                                  Fetched 28.5 MB in 1s (22.4 MB/s)
                                  (Reading database ... 29937 files and directories currently installed.)
                                  Preparing to unpack .../nodejs_18.11.0-deb-1nodesource1_amd64.deb ...
                                  Unpacking nodejs (18.11.0-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
                                  Setting up nodejs (18.11.0-deb-1nodesource1) ...
                                  pi@MagicMirror-live:~$ git clone https://github.com/MichMich/MagicMirror
                                  remote: Enumerating objects: 23768, done.
                                  remote: Counting objects: 100% (1/1), done.
                                  remote: Total 23768 (delta 0), reused 1 (delta 0), pack-reused 23767
                                  Receiving objects: 100% (23768/23768), 19.76 MiB | 12.35 MiB/s, done.
                                  Resolving deltas: 100% (14649/14649), done.
                                  pi@MagicMirror-live:~$ cd MagicMirror/
                                  pi@MagicMirror-live:~/MagicMirror$ npm run install-mm
                                  > magicmirror@2.21.0 install-mm
                                  > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                  npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                                  > magicmirror@2.21.0 postinstall
                                  > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                  > magicmirror@2.21.0 install-vendor
                                  > echo "Installing vendor files ...
                                  > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                  added 9 packages in 5s
                                  > magicmirror@2.21.0 install-fonts
                                  > echo "Installing fonts ...
                                  > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                  added 2 packages in 1s
                                  > magicmirror@2.21.0 prepare
                                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                                  no husky installed.
                                  added 300 packages in 36s
                                  pi@MagicMirror-live:~/MagicMirror$ cp config/config.js.sample config/config.js
                                  pi@MagicMirror-live:~/MagicMirror$ npm run server
                                  > magicmirror@2.21.0 server
                                  > node ./serveronly
                                  [16.10.2022 13:16.02.218] [LOG]   Starting MagicMirror: v2.21.0
                                  [16.10.2022 13:16.02.225] [LOG]   Loading config ...
                                  [16.10.2022 13:16.02.235] [LOG]   Loading module helpers ...
                                  [16.10.2022 13:16.02.236] [LOG]   No helper found for module: alert.
                                  [16.10.2022 13:16.02.252] [LOG]   Initializing new module helper ...
                                  [16.10.2022 13:16.02.254] [LOG]   Module helper loaded: updatenotification
                                  [16.10.2022 13:16.02.254] [LOG]   No helper found for module: clock.
                                  [16.10.2022 13:16.02.513] [LOG]   Initializing new module helper ...
                                  [16.10.2022 13:16.02.514] [LOG]   Module helper loaded: calendar
                                  [16.10.2022 13:16.02.515] [LOG]   No helper found for module: compliments.
                                  [16.10.2022 13:16.02.516] [LOG]   No helper found for module: weather.
                                  [16.10.2022 13:16.02.536] [LOG]   Initializing new module helper ...
                                  [16.10.2022 13:16.02.536] [LOG]   Module helper loaded: newsfeed
                                  [16.10.2022 13:16.02.536] [LOG]   All module helpers loaded.
                                  [16.10.2022 13:16.02.679] [LOG]   Starting server on port 8080 ...
                                  [16.10.2022 13:16.02.695] [LOG]   Server started ...
                                  [16.10.2022 13:16.02.696] [LOG]   Connecting socket for: updatenotification
                                  [16.10.2022 13:16.02.696] [LOG]   Starting module helper: updatenotification
                                  [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: calendar
                                  [16.10.2022 13:16.02.697] [LOG]   Starting node helper for: calendar
                                  [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: newsfeed
                                  [16.10.2022 13:16.02.698] [LOG]   Starting node helper for: newsfeed
                                  [16.10.2022 13:16.02.698] [LOG]   Sockets connected & modules started ...
                                  Ready to go! Please point your browser to: http://localhost:8080
                                  is this now right abd is the info “no helper module” O.K.?
                                  best regards
                                  P.S. when i put “http://localhost:8080” in the browser linie - it´s not going :-(
                                    sdetweil @kusselin
                                    @kusselin remember, a container is a ‘system’
                                    with its own IP address different than than the container hosting system (typically 172.xx.yy.zz)
                                    also, localhost means ONLY apps INSIDE this same ‘system’, can access… so that means a browser running IN the container… oops… not possible
                                    SO, you have to change the MM config.js to allow apps OUTSIDE the container to access the MM app
                                    and THEN on the container setup , map the container MM port to some host port … (so u can access from another pc, phone, tablet, outside the container hosting system )
                                    address:“0.0.0.0”.
                                    ipWhitelist:[],
                                    you didn’t have to reinstall mm… one install runs three ways
                                    full (ui on same ‘system’), npm start
                                    server (ui on some OTHER system (have to change config) npm run server
                                    client (just the UI part), npm run client
                                    • kusselinK Offline
                                      kusselin @sdetweil
                                      @sdetweil what a fu…
                                      now its running!!! Ohman!! yeahhhhhhh :-) thanks a lot…
                                      o.k. i understand …in an lxc is not same as a pi with raspbia…because lxc is an container and has no graphic giu…then i have to start server (npm start server" right…
                                      and i mut change the config as this here
                                      address:“0.0.0.0”.
                                      ipWhitelist:[],
                                        sdetweil @kusselin
                                        @kusselin yes, to help keep this organized for you
                                        think of a container as a pi/nuc/laptop/extra machine with no display, running in text mode
                                        and the only way to get to it is thru a proxy machine (your container host)
                                        and then some other machine, laptop, phone, tablet that wants to display info…
                                        so other machine, phone, tablet connects to proxy, who forwards request to pi, and returns response back.
                                        the proxy doesnt DO anything but transport the info .
                                        • kusselinK Offline
                                          kusselin
                                          thanks sam…YOU ARE THE BEST :-)
                                          • kusselinK Offline
                                            kusselin
                                            one question: Where can i change the position from horizontal to vertical?
                                            In what config can i change that?
                                              sdetweil @kusselin
                                              @kusselin well that becomes much more troublesome…
                                              the container doesn’t have display, so u can’t force it there
                                              also, server mode doesn’t know orientation of display system .
                                              so this would typically be done on system w browser. full system in portrait or landscape.
                                              I don’t know how you would do it just for one browser/tab…
