    MMM-RNV not sisplaying :-(
    7 Posts 3 Posters 1.5k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hi, on my MM2 with a raspi pi 3 i have the same config details as my server…
      On my normalyy MM2 with the pi th module MMM-RNV is displaying all but with the same config on my MM server on a NUC the module is notworking :-(
      always comes the message “RNV Abfahrtsmonitor -> No API credentials provided”
      Here my config fpor both systems:
      		  module: 'MMM-RNV',
      		  header: 'RNV Abfahrstmonitor',
      		  position: 'bottom_right',
      			updateInterval: "60000",
      			animationSpeed: "2000",
      			stationID: "1160", // HD-Bahnhof
      			numJourneys: "10",
      			clientID: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxeb1462d977c8',
      			tenantID: '87cd3xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx16c9',
      			clientSecret: 'zxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx1',
      			resourceID: '148xxxxxxxxxxxxxxxxxxxxxxxxxxxf',
      			coloredLines: "true",
      			showLineIcons: "true",
      			useColorForRealTimeInfo: "true",
      			showTableHeader: "true",
      Has anyone an answer?
      Thanks an best regards
      here with pi3 and O.K.
      and here as “SERVER” on a proxmox LXC Container:
        sdetweil @kusselin
        @kusselin I don’t know.
        did u copy/paste the config?
        or type it again?
        if type again, the system is case sensitive, every letter matters.
        • kusselinK Offline
          kusselin
          I did it with copy & paste
            sdetweil @kusselin
            @kusselin is the address: setting the same on both systems?
            kusselinK 1 Reply Last reply Reply Quote 0
            • kusselinK Offline
              kusselin @sdetweil
              @sdetweil sam, what do you mean about the adress? Ip adress? I dont know what you mean
                sdetweil @kusselin
                @kusselin in config.js,
                address:“localhost” or “0.0.0.0”
                • JalibuJ Offline
                  Jalibu Module Developer
                  @kusselin as already written on GitHub: Please make sure that you don’t quote Numbers and Boolean values in your config.
                  Please also note, that there are multiple implementations of MMM-RNV. The one above only works with Jupadin’s version. My implementation has another object structure.
