    Is there a way . . .
    23 Posts 8 Posters 9.0k Views 8 Watching
      Mykle1 Project Sponsor Module Developer @johnnyboy
      @johnnyboy Yeah, that one’s a keeper
      • BKeyportB Offline
        BKeyport Module Developer @strawberry 3.141
        @strawberry-3-141 Just found this, bless you. Should be in the magic mirror documentation.
          j.e.f.f Project Sponsor Module Developer @strawberry 3.141
          @strawberry-3-141 said in Is there a way . . .:
          @Mykle1 put that in custom.css
          body {
            margin: 20px;
            height: calc(100% - 40px);
            width: calc(100% - 40px);
          Might I suggest a small change… 100% can be interpreted by the browser in unexpected ways under certain circumstances. Sometimes when you specify 100% for height, the browser interprets this to mean 100% of the width. This is a safer way to do it:
          body {
            margin: 20px;
            height: calc(100vh - 40px);
            width: calc(100vw - 40px);
          vh stands for Viewport Height, similarly vw stands for Viewport Width. Viewport width and height refer to the browser window’s interior size, or in the case of an iFrame, the iFrame’s interior size – essentially the space in which the HTML DOM is visible. A value of 1vw is equal to 1% of the viewport’s width, 33vh is equal to 33% of the viewport’s height, etc.
          vw and vh are especially useful when you want to scale elements relative to the available screen space.
          • BKeyportB Offline
            dang. For some reason, that brings it even tighter to the edges than %. Weird.
            I highly recommend the following for use on the official 7" touchscreen display. Gets you the maximum screen usage.
            (I have a mini-display magic mirror for work.) :)
            body {
            margin: 0px;
            height: calc(100vh - 10px);
            width: calc(100vw - 5px);
            michael5rM 1 Reply Last reply Reply Quote 0
            • michael5rM Offline
              michael5r Module Developer @BKeyport
              @bkeyport said in Is there a way . . .:
              body {
              margin: 0px;
              If your margin is 0px, there’s no need to subtract anything from the height and width - they could just be 100vh and 100vw respectively.
              • ? Offline
                A Former User
                :root {
                  --body-margin : 20px;
                body {
                  margin: var(--body-margin);
                  width: calc(100vw - var(--body-margin) * 2);
                  height: calc(100vh - var(--body-margin) * 2);
                BKeyportB 1 Reply Last reply Reply Quote 1
                • BKeyportB Offline
                  BKeyport Module Developer @michael5r
                  @michael5r Actually, if I don’t subtract, the margins run clear off the right side and bottom of the screen, using the official 7" touchscreen, those subtractions bring it back to 100%
                  • BKeyportB Offline
                    BKeyport Module Developer @Guest
                    @sean Can you explain your body code a bit? I’m not quite following it.
                    • ? Offline
                      A Former User @BKeyport
                      @bkeyport
                      In modern CSS, you can use variables. If you are using values referenced frequently or dependently, you can set that value as variables.
                      In prior example, --body-margin is defined. Now you can use it instead static fixed value 20px. So when you have to change that value, just modify --body-margin once.
                      • BKeyportB Offline
                        This is the part that’s getting me…
                        width: calc(100vh - var(–body-margin) * 2);
                        height: calc(100vw - var(–body-margin) * 2);
                        If I’m reading this correctly - it’s taking the calculation of 100% of the viewpoint(direction) - the margin defined in the varible multiplied by 2?
                        100% of the viewport height minus 40 pixels in your example?
                        ? S 2 Replies Last reply Reply Quote 0
                        • 3 / 3
