    Display different Roomtemperature on MagicMirror
    31 Posts 4 Posters 11.8k Views 4 Watching
    • XilefX Offline
      Xilef @wishmaster270
      @wishmaster270 i guess thats what i need
      “Always assign the same IPv4 address to this network device.”
      And for the WIFI SSID and Passwort, behind the 2 ## right?
      and where do i need to use the nc command? on the esp32 or on the raspberry pi?
      • wishmaster270W Offline
        wishmaster270 Module Developer @Xilef
        @Xilef
        Perfect. This is the right setting.
        You need to replace the ##, too.
        It will look something like:
        const char* ssid     = "MY_WIFI_NETWORK";
        const char* password = "123ABC456";
        IPAddress local_IP(192, 168, 178, 106);
        IPAddress gateway(192, 168, 178, 1);
        IPAddress subnet(255, 255, 255, 0);
        IPAddress primaryDNS(192, 168, 178, 1);
        IPAddress secondaryDNS(8, 8, 8, 8);
        To check if everything is set up correctly you can run:
        /bin/nc -w3 192.168.178.106 80
        XilefX 1 Reply Last reply Reply Quote 0
        • XilefX Offline
          @wishmaster270 the “/bin/nc -w3 192.168.178.106 80” command on the serial monitor message line?
          I would suggest to remove the clamp behind the ; ??
            @Xilef
            Sorry, my fault. You need to change line 52 to:
            if (!bme.begin(0x76)) {
            Copy&Paste mistake of me
            • XilefX Offline
              @wishmaster270 i installed the module, but i cant display the data
              what am i doing wrong, ah the esp32 says he couldnt find a sensor, thats weird
              (edit: i tried another one and it worked this time)
                @Xilef
                You will need the MMM-Temperature module and not the Embed module as you do not want to display a website but parse the JSON data object and display its contents.
                The config will look something like:
                			module: "MMM-Temperature",
                			position: "bottom_right",
                				sensors: [
                					    script: "/bin/nc",
                					    args: "-w3 192.168.178.106"
                But you will need to fix the missing sensor first.
                Can you please check your wiring and use this sketch instead of the other one. I only removed one line which i do not think is the problem but i can not test the sketch at the moment.
                #include <WiFi.h>
                #include <Wire.h>
                #include <Adafruit_Sensor.h>
                #include <Adafruit_BME280.h>
                const char* ssid     = "##ADD_WIFI_SSID_HERE";
                const char* password = "##ADD_WIFI_PASSWORD_HERE";
                //ENTER STATIC IP OF THE ESP32 BOARD HERE
                IPAddress local_IP(192, 168, 0, 2);
                IPAddress gateway(192, 168, 0, 1);
                IPAddress primaryDNS(192, 168, 0, 1);
                Adafruit_BME280 bme;
                WiFiServer server(80);
                void setup()
                  Serial.begin(115200);
                  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
                    Serial.println("STA Failed to configure");
                  Serial.print("Connecting to ");
                  Serial.println(ssid);
                  WiFi.begin(ssid, password);
                  while (WiFi.status() != WL_CONNECTED) {
                    delay(500);
                    Serial.print(".");
                  Serial.println("");
                  Serial.println("WiFi connected!");
                  Serial.print("IP address: ");
                  Serial.println(WiFi.localIP());
                  Serial.print("ESP Mac Address: ");
                  Serial.println(WiFi.macAddress());
                  Serial.print("Subnet Mask: ");
                  Serial.println(WiFi.subnetMask());
                  Serial.print("Gateway IP: ");
                  Serial.println(WiFi.gatewayIP());
                  Serial.print("DNS: ");
                  Serial.println(WiFi.dnsIP());
                    Serial.println("Couldn't find sensor!");
                    while (1);
                  server.begin();
                void loop()
                  float temp = bme.readTemperature();
                  float tempf = temp * 1.8 + 32;
                  float rel_hum = bme.readHumidity();
                  WiFiClient client = server.available();
                  if (client) {
                    Serial.println("New Client.");
                    client.println("{");
                    client.print("  \"temperature_c\": ");
                    client.print(temp);
                    client.println(",");
                    client.print("  \"temperature_f\": ");
                    client.print(tempf);
                    client.print("  \"humidity\": ");
                    client.print(rel_hum);
                    client.println("  \"error\": false");
                    client.println("}");
                    client.stop();
                    Serial.println("Client disconnected.");
                    Serial.println("");
                  delay(100);
                XilefX 2 Replies Last reply Reply Quote 0
                • XilefX Offline
                  @wishmaster270 i connected an other sensor and it doesnt showed me the error message, i will try the sketch tomorrow, the MMM_Temperature module is installed and works, but doesnt show any data, im gona try to fix it tomorrow
                  • XilefX Offline
                    @wishmaster270 everything worked, you just forgot to add the “80” here:
                    i just set up a second sensor and cloned the module
                    if i go into my browser and type the two different IPs every sensor shows his own data, but the mirror displays 2times the data of sensor 2:
                    (sensor1: “test” | sensor2: “test2”)
                    how do i fix that?
                      @Xilef Perfect. One step further.
                      You only need one instance of the module. So your config will look something like:
                      			position: "middle_center",
                      				sensors: [
                      					    script: "/bin/nc",
                      					    args: "-w3 192.168.178.106 80"
                      					    script: "/bin/nc",
                      					    args: "-w3 192.168.178.108 80"
                      • XilefX Offline
                        @wishmaster270 yes, it works
                        and in the future i can experiment with the MMM-ValuesByNotification Module to customize the module, right?
                        and a big thank you for the help and the quick reply
                        • 3 / 4
