    Step by step guide to MagicMirror on Ubuntu 22 server?
    10 Posts 2 Posters 3.1k Views 2 Watching
    • E Offline
      eqpaisley
      I’ve seen some guides for MagicMirror on linux but I am on the struggle bus trying to setup MM on a remote VPS (via SSH). Ubuntu 22 on ARM architecture. Is there a guide floating around? Has anyone done this?
        sdetweil @eqpaisley
        @eqpaisley what is a VPS ?
        but, run my script to install
        see
        E 4 Replies Last reply Reply Quote 0
        • E Offline
          eqpaisley @sdetweil
          @sdetweil thanks! can I use this curl command?
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
          • E Offline
            eqpaisley @sdetweil
            @sdetweil oh sorry - a vps is a remote, virtual machine. but it functions exactly like a low power (2cores 8g of ram) ARM machine.
              sdetweil @eqpaisley
              @eqpaisley does it have a local UI?
              if not, then you do
              npm run server
              to execute the server
              and then view with a browser somewhere else
              there is one install, and three different run modes
              full
              server
              client
              • E Offline
                eqpaisley @sdetweil
                @sdetweil great ty. Yeah the plan is to run this non-gui version in server mode. I’ll need to edit the config to allow remote connections from my IPs and open the right ports, etc it will be a process lol but I think I can sort it out.
                • E Offline
                  eqpaisley @sdetweil
                  @sdetweil could you remind me of the command to run NPM RUN SERVER in the background so it won’t quit when I close my SSH session?
                  Also, if I need to re-run the server (let’s say I update the config or add a module) how do I do that?
                    sdetweil @eqpaisley
                    @eqpaisley if u setup pm2, then
                    pm2 status will show u the managed apps
                    pm2 --help will show u all the things it can do
                    pm2 start
                    pm2 restart
                    pm2 stop
                    pm2 info
                    all take the name of the app, or the number
                    if u setup pm2 q my script then it launches
                    MagicMirror/installers/mm.sh
                    change the npm start to npm run server
                    if u didn’t setup pm2, then the script on my script
                    fixuppm2.sh will do that
                    • E Offline
                      eqpaisley @sdetweil
                      @sdetweil Thanks! I ended up setting up a magicmirror.service. now I use
                      sudo service magicmirror resart
                      after each tweak to my config. I have it up and running on a free oracle cloud instance and behind a reverse proxy.
                      I guess the danger there is that anyone with the URL can access it…but they’d have to guess the URL…right?
                        sdetweil @eqpaisley
                        @eqpaisley right
